- Forum posts: 1
May 9, 2015, 5:37:40 AM via Website
May 9, 2015 5:37:40 AM via Website
I'm strongly considering buying an LG G2, and just have a couple of questions about it....
Do you guys (who have this phone) think that it's too big? Does it fit nicely in your jeans pocket, shorts pocket, etc? Does it feel too tight, too uncomfortable?
Can you change the way you unlock the phone? Is there an option for a passcode/password?
Will it accidentally turn on in your pocket through either the back buttons or the "Knock-On" feature? I.e. Will the phone think you are double tapping it when it's in your pocket?
Will the phone spin around when you put it on its back (because the buttons are raised higher than the rest of the phone)?
Is the screen in fact smaller than the Galaxy s4 because of the on-screen buttons? In the LG G2, it has on-screen buttons, which might take up too much space, resulting in the screen size going from 5.2 inch to something like 5 inch??
Do you think it's better than the Galaxy s4?
Thank you so much for taking the time to read this and helping me out ? I really appreciate it!
