- Forum posts: 1
Apr 23, 2015, 4:32:43 PM via App
Apr 23, 2015 4:32:43 PM via App
Greetings All,
Guys I have one hell of a weird issue here...I'm using the great nexus 6 Motorola since I have updated the L 5.1 > an freaking weird issue came up which is the volume bar is not changeable even if I try to volume it up thru the settings its turned off meaning I can't also control it and of course for incoming calls no sound at all only the vibration despite that the speaker is working perfectly fine for all other apps, music etc.
The other strange thing here some times I can control the volume but even when I do still the ringtone for incoming calls is totally dead...this issue happens during the day between 5-6 times.
I looked for similar issue thru all out the network forums of nexus and android bugs/issues... there's nothing.
I'm really confused here and really appreciate any advice from you guys.
NOTE : I HAVE FORMATTED (FACTORY RESET) THE DEVICE TWICE BUT THE ISSUE STILL PERSISTS !
Kind Regards
