Here i my code for a Fragment menu,But when i inserted swipe menu in this fragment there is a n error displays that "Type mismatch: cannot convert from FindPeopleFragment to Fragment".
Can anybody help me to sort ou the issue.
Here is my codes.
Main activity
import info.androidhive.slidingmenu.adapter.NavDrawerListAdapter;
import info.androidhive.slidingmenu.model.NavDrawerItem;
import java.util.ArrayList;
import android.app.Activity;
import android.app.Fragment;
import android.app.FragmentManager;
import android.content.Intent;
import android.content.res.Configuration;
import android.content.res.TypedArray;
import android.os.Bundle;
import android.support.v4.app.ActionBarDrawerToggle;
import android.support.v4.widget.DrawerLayout;
import android.util.Log;
import android.view.Menu;
import android.view.MenuItem;
import android.view.View;
import android.widget.AdapterView;
import android.widget.ListView;
public class MainActivity extends Activity {
private DrawerLayout mDrawerLayout;
private ListView mDrawerList;
private ActionBarDrawerToggle mDrawerToggle;
// nav drawer title
private CharSequence mDrawerTitle;
// used to store app title
private CharSequence mTitle;
// slide menu items
private String[] navMenuTitles;
private TypedArray navMenuIcons;
private ArrayList<NavDrawerItem> navDrawerItems;
private NavDrawerListAdapter adapter;
@Override
protected void onCreate(Bundle savedInstanceState) {
super.onCreate(savedInstanceState);
setContentView(R.layout.activity_main);
mTitle = mDrawerTitle = getTitle();
// load slide menu items
navMenuTitles = getResources().getStringArray(R.array.nav_drawer_items);
// nav drawer icons from resources
navMenuIcons = getResources()
.obtainTypedArray(R.array.nav_drawer_icons);
mDrawerLayout = (DrawerLayout) findViewById(R.id.drawer_layout);
mDrawerList = (ListView) findViewById(R.id.list_slidermenu);
navDrawerItems = new ArrayList<NavDrawerItem>();
// adding nav drawer items to array
// Home
navDrawerItems.add(new NavDrawerItem(navMenuTitles[0], navMenuIcons.getResourceId(0, -1)));
// Find People
navDrawerItems.add(new NavDrawerItem(navMenuTitles[1], navMenuIcons.getResourceId(1, -1)));
// Photos
navDrawerItems.add(new NavDrawerItem(navMenuTitles[2], navMenuIcons.getResourceId(2, -1)));
// Communities, Will add a counter here
navDrawerItems.add(new NavDrawerItem(navMenuTitles[3], navMenuIcons.getResourceId(3, -1), true, "22"));
// Pages
navDrawerItems.add(new NavDrawerItem(navMenuTitles[4], navMenuIcons.getResourceId(4, -1)));
// What's hot, We will add a counter here
navDrawerItems.add(new NavDrawerItem(navMenuTitles[5], navMenuIcons.getResourceId(5, -1)));
navDrawerItems.add(new NavDrawerItem(navMenuTitles[6], navMenuIcons.getResourceId(6, -1)));
navDrawerItems.add(new NavDrawerItem(navMenuTitles[7], navMenuIcons.getResourceId(7, -1), true, "50+"));
// Recycle the typed array
navMenuIcons.recycle();
mDrawerList.setOnItemClickListener(new SlideMenuClickListener());
// setting the nav drawer list adapter
adapter = new NavDrawerListAdapter(getApplicationContext(),
navDrawerItems);
mDrawerList.setAdapter(adapter);
// enabling action bar app icon and behaving it as toggle button
getActionBar().setDisplayHomeAsUpEnabled(true);
getActionBar().setHomeButtonEnabled(true);
mDrawerToggle = new ActionBarDrawerToggle(this, mDrawerLayout,
R.drawable.ic_drawer, //nav menu toggle icon
R.string.app_name, // nav drawer open - description for accessibility
R.string.app_name // nav drawer close - description for accessibility
public void onDrawerClosed(View view) {
getActionBar().setTitle(mTitle);
// calling onPrepareOptionsMenu() to show action bar icons
invalidateOptionsMenu();
public void onDrawerOpened(View drawerView) {
getActionBar().setTitle(mDrawerTitle);
// calling onPrepareOptionsMenu() to hide action bar icons
mDrawerLayout.setDrawerListener(mDrawerToggle);
if (savedInstanceState == null) {
// on first time display view for first nav item
displayView(0);
* Slide menu item click listener
private class SlideMenuClickListener implements
ListView.OnItemClickListener {
@Override
public void onItemClick(AdapterView<?> parent, View view, int position,
long id) {
// display view for selected nav drawer item
displayView(position);
@Override
public boolean onCreateOptionsMenu(Menu menu) {
getMenuInflater().inflate(R.menu.main, menu);
return true;
@Override
public boolean onOptionsItemSelected(MenuItem item) {
// toggle nav drawer on selecting action bar app icon/title
if (mDrawerToggle.onOptionsItemSelected(item)) {
return true;
// Handle action bar actions click
switch (item.getItemId()) {
case R.id.action_settings:
return true;
default:
return super.onOptionsItemSelected(item);
* Called when invalidateOptionsMenu() is triggered
@Override
public boolean onPrepareOptionsMenu(Menu menu) {
// if nav drawer is opened, hide the action items
boolean drawerOpen = mDrawerLayout.isDrawerOpen(mDrawerList);
menu.findItem(R.id.action_settings).setVisible(!drawerOpen);
return super.onPrepareOptionsMenu(menu);
* Diplaying fragment view for selected nav drawer list item
private void displayView(int position) {
// update the main content by replacing fragments
Fragment fragment = null;
switch (position) {
case 0:
fragment = new HomeFragment();
break;
case 1:
fragment = new FindPeopleFragment();
break;
case 2:
fragment = new PhotosFragment();
break;
case 3:
fragment = new CommunityFragment();
break;
case 4:
fragment = new PagesFragment();
break;
case 5:
fragment = new WhatsHotFragment();
break;
default:
break;
if (fragment != null) {
FragmentManager fragmentManager = getFragmentManager();
fragmentManager.beginTransaction()
.replace(R.id.frame_container, fragment).commit();
// update selected item and title, then close the drawer
mDrawerList.setItemChecked(position, true);
mDrawerList.setSelection(position);
setTitle(navMenuTitles[position]);
mDrawerLayout.closeDrawer(mDrawerList);
} else {
// error in creating fragment
Log.e("MainActivity", "Error in creating fragment");
@Override
public void setTitle(CharSequence title) {
mTitle = title;
* When using the ActionBarDrawerToggle, you must call it during
* onPostCreate() and onConfigurationChanged()...
@Override
protected void onPostCreate(Bundle savedInstanceState) {
super.onPostCreate(savedInstanceState);
// Sync the toggle state after onRestoreInstanceState has occurred.
mDrawerToggle.syncState();
@Override
public void onConfigurationChanged(Configuration newConfig) {
super.onConfigurationChanged(newConfig);
// Pass any configuration change to the drawer toggls
mDrawerToggle.onConfigurationChanged(newConfig);
*FindPeopleFragment *
import android.annotation.SuppressLint;
import android.app.ActionBar;
import android.app.FragmentTransaction;
import android.support.v4.app.FragmentActivity;
import android.support.v4.view.ViewPager;
import android.view.LayoutInflater;
import android.view.ViewGroup;
@SuppressLint("NewApi") public class FindPeopleFragment extends FragmentActivity {
ViewPager Tab;
TabPagerAdapter TabAdapter;
ActionBar actionBar;
@Override
setContentView(R.layout.fragment_find_people);
TabAdapter = new TabPagerAdapter(getSupportFragmentManager());
Tab = (ViewPager)findViewById(R.id.pager);
Tab.setOnPageChangeListener(
new ViewPager.SimpleOnPageChangeListener() {
@Override
public void onPageSelected(int position) {
actionBar = getActionBar();
actionBar.setSelectedNavigationItem(position); }
Tab.setAdapter(TabAdapter);
//Enable Tabs on Action Bar
actionBar.setNavigationMode(ActionBar.NAVIGATION_MODE_TABS);
ActionBar.TabListener tabListener = new ActionBar.TabListener(){
@Override
public void onTabReselected(android.app.ActionBar.Tab tab,
FragmentTransaction ft) {
// TODO Auto-generated method stub
@Override
public void onTabSelected(ActionBar.Tab tab, FragmentTransaction ft) {
Tab.setCurrentItem(tab.getPosition());
@Override
public void onTabUnselected(android.app.ActionBar.Tab tab,
//Add New Tab
actionBar.addTab(actionBar.newTab().setText("Android").setTabListener(tabListener));
actionBar.addTab(actionBar.newTab().setText("iOS").setTabListener(tabListener));
actionBar.addTab(actionBar.newTab().setText("Windows").setTabListener(tabListener));
— modified on Nov 19, 2014, 12:26:34 PM
