Hello, I have just updated my sghi337 to 4.4.2, but I noticed my mobile Internet is working very slow
Any suggestions how to downgrade to 4.2.2? Thanks
Thank you for finally posting in the forum about your problem. This is the place to ask questions for these types of things, not in every article.
Would you be able to specify the internet problem that you are having, like does it keep on dropping for example? I doubt that downgrading is the solution. Also, you may be next in line for a new upgrade to Android 4.4.3 that could help fix this, if it happens to be a bug.
Let us know a bit more and we will try to help you.
Hello there, the problem I am having is when am using the mobile Internet it takes a very long time to open the page, sometimes it doesn't it says error. When am using the wi Fi though it works very well. Before I update, it was working very well on 4.2.2. Any solution. Thanks
Jul 10, 2014, 7:32:13 AM via Website
Jul 10, 2014 7:32:13 AM via Website
In this link 10 solution of samsung galexy s4, for your problem click here-
www.digitaltrends.com/mobile/samsung-galaxy-s4-problems/#!bb2vk5
Jul 10, 2014, 9:38:41 AM via Website
Jul 10, 2014 9:38:41 AM via Website
you just wait for a new upgradation 4.4.3 install the previous one
Hello rikimilton,that link is not opening..
Hello, what can I do to fix my mobile Internet.
Jul 11, 2014, 11:17:45 AM via Website
Jul 11, 2014 11:17:45 AM via Website
hopeton
The 4.4.3 Android release should appear on the S4 in July, so iff this was a problem caused by 4.4.2, download the update when it becomes available and see if that fixes the issue.
Ok thanks scott.
