How to speed up your android mobile
  • Closed
yaseen ramzan
  • Forum posts: 13
Oct 21, 2019, 8:39:06 PM via Website
Do you want to speed up your android mobile speed then you are in the right place. Today i am going to show you how to speed up your android mobile in three steps
Remove unwanted Apps from your android mobile
uncheck all the transitions from setting of your android mobile
Forcefully stop all the running process
Congrats now your anroid mobile speed is increased.
  • Forum posts: 1,011
Oct 22, 2019, 3:27:50 AM via Website
uncheck all the transitions from setting of your android mobile (meaning ?)
Helpful?
Rubaris
  • Forum posts: 16
Nov 14, 2019, 10:52:35 AM via Website
Hi thanks for this information !
Helpful?
Rubaris
  • Forum posts: 16
Nov 14, 2019, 10:53:12 AM via Website
Helpful?
Olivia Eve
  • Forum posts: 5
Aug 28, 2023, 8:25:39 AM via Website
To speed up your Android mobile device, follow these steps:
  1. Clear Cache: Regularly clear app caches through Settings > Storage.
  2. Remove Unused Apps: Uninstall apps you no longer use to free up resources.
  3. Update Apps and OS: Keep your apps and Android OS updated for improved performance.
  4. Limit Background Processes: Reduce the number of background apps running in Developer Options.
  5. Use Lightweight Apps: Opt for lighter alternatives to resource-heavy apps.
  6. Disable Animations: Disable or reduce animation scales in Developer Options.
  7. Manage Widgets: Minimize widgets on your home screen to save processing power.
  8. Free Up Storage: Delete old files, photos, and unused data to free up space.
  9. Restart Regularly: Reboot your device to clear temporary files and refresh system processes.
  10. Disable Bloatware: Disable unnecessary pre-installed apps that can slow down your device.
Implementing these tips should help enhance your Android device's speed and overall performance.
Helpful?
