Samsung Z1 automatically ignoring incoming calls
Elsa Bailey
  • Forum posts: 26
Aug 12, 2019, 9:14:13 AM via Website
I have this old Samsung Z1 mobile phone. it works fine but the thing is whenever it gets an incoming call it ignores the call and sending an automated text automatically. I tried to reset it. But after a few days, the problem arises the same as before.
Does anyone have a solution for this matter?
James Watson
  • Forum posts: 1,605
Aug 12, 2019, 12:10:19 PM via Website
Check whether your device supports some feature like 'Do Not Disturb While Driving' mode.
Or go through every apps installed on your device. Some 3rd-party apps may also get 'Do Not Disturb While Driving' mode active for an Android phone.
— modified on Aug 18, 2019, 6:01:41 AM
Helpful?
James Watson
Aug 12, 2019, 12:11:39 PM via Website
For instance, the free app Driving Detective is based on the same “Do Not Disturb While Driving” software Google developed for the Pixel 2. It also works with any device running Android 4.1 or up, and setting it up is easy.
Helpful?
  • Forum posts: 1,011
Aug 16, 2019, 11:08:07 AM via Website
If it is an app sending it out it probably says, at the end of the message, the name of the app.
Helpful?
Elsa Bailey
  • Forum posts: 26
Aug 16, 2019, 12:28:03 PM via Website
I already check if it is an app and not. And I forgot to mention this issue begun to rise when I replace the screen of the device due to some cracks on it. But it was working just fine at that time. After awhile this starts to happen. I guess it is better if I give it to the repair shop again. right?
Helpful?
