Weight not logging correctly in Fit
Olivia Cookfair
Mar 16, 2019, 7:39:25 PM via Website
I have the nokia smart scale and have paired it with Google fit & MyFitnessPal but it seems instead of showing and linking with my other logged weight entries, it just shows up as pale blue dots. Is there a way to make it one flow chart?
Screenshot_20190316 143236
  • Forum posts: 770
Mar 16, 2019, 8:32:12 PM via Website
Go to https://fit.google.com, and scroll down till you reach a chart with your activities. To the right-hand side, there is a button that says "Active Time" - you can click that and change to weight.
sync between devices required an excellent wifi signal.
— modified on Mar 16, 2019, 8:32:50 PM
Ready To Help You.
Helpful?
