- Forum posts: 2
Nov 28, 2018, 8:43:02 AM via Website
Nov 28, 2018 8:43:02 AM via Website
What's the Quick Charge 3.0 /2.0
Quick Charge 2.0
QC 2.0 is actually the latest mobile phone fast charging solution combined with Qualcomm® 800 series chipset.
A wall charger that can adaptively output 5V 9V or12v based on the Quick Charge 2.0 protocol quickly charge mobile phones which support the Quick Charger 2.0 protocol. The working principle of QC2.0 fast charging technology is to increase the output voltage under the condition of charging current limit, so that the maximum charging power is further increased, and the charging time is greatly shortened. And divided into two industry standards A and B. A standard is 5V 9V 12V output voltage. B standard: is 5v 9v 12v and 20V output voltage.
QC 2.0 charger
Quick Charge 3.0
After the popularization of Quick Charge 2.0, Qualcomm announced the launch of Qualcomm-quick change 3.0, the next generation of fast charging technology. As the third generation of fast charging technology, Quick Charge 3.0 adopts Intelligent Negotiation for optimum voltage (INOV) for the first time in its class, The INOV is a new algorithm developed by Qualcomm technologies to help portable devices with the ability to select the required power level to achieve optimal power transfer at any time and to increase efficiency. For the first time, Quick Charge 3.0 uses intelligent negotiation for Optimum Voltage -INOV, which enables good power transfer at any time and maximizes efficiency.
Quick Charge 3.0 is forward and backward compatible with pre-Quick Charge versions and chargers (including USB Type-C), and has the same ultra-fast charging speed and independent circuitry, giving OEM factory more flexibility to choose from. There is a UL certification to help achieve quality and safety standards, QC2.0 does not.
Quick charge 3.0 can charge a regular mobile phone from 0% to 80% in about 35 minutes. A conventional mobile terminal device without a quick charge usually takes about one and a half hours. Compared to the previous generation, Quick Charge 3.0 with INOV and other advanced technologies can achieve a 38% efficiency improvement over the quick charge 2.0, while using other methods to help protect the battery life cycle.
QC 3.0 power bank
Application:
Wall charger, car charger, Quick charge power banks, fast charging power bank etc.
Heloideo New Power bank support Quick Charge :
1. 20000mah Power bank with extending charging cable and hidden AC plug inside. support PD 18W, QC3.0. ofcourse, 36W 45W also available too and work as laptop Power bank.
- power bank 10000 QC 3.0 Fast Charging Power bank charger, also support to PD 3.0.
link heloideo dot com more details about the power bank 10000 and fast charging power banks.
