Gmail problem
  • Answered
  • Forum posts: 819
Jul 24, 2018, 11:32:20 PM via Website
Hi all
Just got a new galaxy s7.
Every time I open gmail this notification pops up ;
There was a problem syncing your folder please try again.
This message only shows for a brief moment then gmail functions as normal. Anyone know what might be causing this?
Best answer
  • Forum posts: 819
Jul 28, 2018, 1:05:35 AM via Website
James
Just found out that Google is having a major problem world wide with the gmail app. They say they have a team working on it.
Forgive me for sending this message to you but I wanted to add it to this post and I didn't know how else to do it.
Lindsay
Helpful?
James Watson
  • Forum posts: 1,607
Jul 25, 2018, 3:47:47 AM via Website
Do you use the stock email app or gmail app?
It seems that your gmail has stopped syncing automatically on your phone. Check its sync setting.
— modified on Jul 25, 2018, 3:48:07 AM
Helpful?
  • Forum posts: 819
Jul 25, 2018, 3:59:27 AM via Website
James
I use gmail and auto-sync is on!
Thanks anyway!
Helpful?
James Watson
Jul 25, 2018, 4:18:33 AM via Website
If so, I think you may check your battery save setting & network setting to make sure the background of your gmail app to work always properly. Just for your reference.
Helpful?
edwardyeager
  • Forum posts: 13
Jul 25, 2018, 9:31:10 AM via Website
You can also master refresh the phone if the problem still persists !!
Master refresh will make your phone working well without affecting any files on your phone !!
Helpful?
  • Forum posts: 819
Jul 25, 2018, 11:55:54 AM via Website
James
Power saving mode is off.
Network setting are good.
Helpful?
  • Forum posts: 819
Jul 25, 2018, 12:17:54 PM via Website
I check the internet.
There is no such thing as a Master Refresh!
Did you mean a soft reset?
Helpful?
James Watson
Jul 25, 2018, 4:55:33 PM via Website
I am not sure About your phone. But for my mobile, there is a setting option, screen lock cleanup. The gmail APP in the list here should be set to 'disable'.
The screenshot is as below. FYI.
Screenshot_2018 07 25 22 21 29
Helpful?
edwardyeager
  • Forum posts: 13
Jul 25, 2018, 8:25:52 PM via Website
Yes there are various names of this !! Soft reset can fix this as one of my friend also persists the same and it was solved by soft reset !!
Please also let me know the output !!
Helpful?
David Vitta
  • Forum posts: 16
Jul 25, 2018, 9:23:56 PM via Website
i have also faced it
Helpful?
  • Forum posts: 819
Jul 25, 2018, 11:25:19 PM via Website
James
I have a galaxy s7. It is a unlocked device! Which means no cell phone carrier got to reprogram it between me and samsung!
Looked all through gmail and security settings.
Can't find anything called lock screen clean up .
Lindsay
Helpful?
  • Forum posts: 819
Jul 25, 2018, 11:33:28 PM via Website
Edwardyeager
I have a unlocked galaxy s7!
I have searched everywhere. All I can find is a Hard Factory Reset!
And I really don't want to have to reprogram everything for this annoying little glitch.
Could this soft reset be called something else?
Helpful?
Best answer
  • Forum posts: 819
James
Lindsay
Helpful?
Caroline Grey
  • Forum posts: 8
Jul 31, 2018, 5:36:17 AM via Website
Just check the internet.
Helpful?
  • Forum posts: 819
Jul 31, 2018, 11:52:48 AM via Website
Caroline grey
I already checked the internet.
That's how I found out Google was having problems .
What are you suggesting I check the internet for now.
Helpful?
