- Forum posts: 1
May 8, 2018, 12:11:58 AM via Website
May 8, 2018 12:11:58 AM via Website
Hi
I have a problem with messaging via whatsup, It does not give me an Enter key to go down to next line while typing a message
Hi
Which keyboard do you use? Usually, the arrow button on the bottom-right corner should start a new line.
May 8, 2018, 6:40:06 AM via Website
May 8, 2018 6:40:06 AM via Website
ShireWhatsup
Hi
Do you mean Enter key in WhatsApp messenger? If yes, there is an option about the effect of this key.
WhatsApp - Settings - Chat.
Download size < 0.07 MB. But also Accurate, Ad-Free & Full-Free.
The minimalist app available on Google Play https://goo.gl/ws42fN
Your 5-star is appreciated. Blog : https://okblackcafe.blogspot.com
Enter key never work while giving reply from notification bar directly
For chatting we can change setting for enter key preference
