Android 6 battery drian
Paul eastgate
Apr 21, 2018, 4:56:51 PM via Website
Hi all have just brought a generic phone running on android 6, every weekday morning between 7 am and 9 am the battery dies in about half an hour. After charging again it will last all day then the same thing happens the next morning, weekends this doesn't happen. During time of drain WiFi,data, location, Bluetooth are all turned off . Any ideas how to stop this
James Watson
  • Forum posts: 1,605
Apr 22, 2018, 10:55:46 AM via Website
You can see which apps are using up your battery by going to the Battery section in the Settings menu.
If you find that an app is causing an abnormal amount of battery drain, your best bet is to uninstall that particular app. These issues can often be fixed with a software update, so once an update for that app rolls out, you should be able to install it once again.
Helpful?
Rachael Alice
  • Forum posts: 162
Apr 23, 2018, 8:10:34 AM via Website
I haven't come across such issue before which absorbs battery due to alarm. But yeah as James_Watson said look which apps are consuming so much battery first. May it can help you better.
https://play.google.com/store/apps/details?id=com.autostamper.datetimestampphoto&hl=en
Helpful?
Larry Pelky
  • Forum posts: 13
Aug 18, 2018, 6:34:35 AM via Website
Uninstall the apps which are draining the battery mostly. if not then you can also make them in sleep mode so they not using your battery as well data.
optimize your battery performance through built in battery optimizer located in settings.
Helpful?
