Is it possible to read/write to SQLite on a removable USB Flash Drive
Mark Anderson
Apr 6, 2018, 12:41:34 AM via Website
Is it possible to read/write to SQLite on a removable USB Flash Drive, by this I mean the app is installed on the phone, but the data used by the app would be stored on a removable USB flash drive that plugs into the USB/Charging port.
I have been reading a lot and for the most part references to this suggest the data must be in the same location as the app. I need the data to be external to the app so different databases can be used as required. If it is possible, I would appreciate a reference to some example or explanation.
thanks
James Watson
  • Forum posts: 1,608
Apr 6, 2018, 4:04:01 AM via Website
We can read/write to SQLite on a SD card. So I think you can do on an USB drive, too.
public static final String DATABASE_FILE_PATH = "/sdcard";
public static final String DATABASE_NAME = "testDatabase";
database = SQLiteDatabase.openOrCreateDatabase(DATABASE_FILE_PATH + File.separator + DATABASE_NAME, null);
Helpful?
Mark Gonzales
  • Forum posts: 22
Apr 6, 2018, 5:41:36 AM via Website
Hi Mark,
Yes, you can save the app on your SD card which will work same as the app is installed on the phone, however, it is still best for all our apps both internal and external to be installed directly to the phone memory. Hope this helps
Helpful?
