The power bank is no stranger to everyone, it is already a part of People’s Daily Necessities. Anyone who uses a smart-phone knows the importance of carrying a backup power bank. But given the overwhelming number of options on the website, you might feel overwhelmed, understandably. Because you chose the ordinary power bank, you need to consider the various charging specs, ports, and even cable, after that you need to consider what cable and charger charging for your power bank and cellphone when you travel. Now, it doesn’t need that much trouble, we found some new multi-function power banks - 2-in-1 wall charger power bank. Today, we will give you a guide to buying the best 2in1 wall charger power bank.
1 Anker
Anker PowerCore Fusion Portable Charger 5000mAh Wall Charger Power Bank
Anker 5000mAh wall charger power bank used their exclusive PowerIQ and VoltageBoost technologies ensure that all devices receive fastest possible charge. Anker wall charger power bank cannot charge your devices while being charged. It compatible with iPhone, iPad, Android, Samsung Galaxy and more.
Specification:
Brand: Anker
Capacity: 5000mAh
AC Input: 100-240V~0.5A 50-60Hz
Micro USB Input: 5V=2A
USB Output (when plugged into AC): 5V=2.1A (2.1A Max Each Port)
USB Output (when not plugged into AC): 5V=3A (3A Max Each Port)
2 Tattu
Tattu 2in1 5200mah AC Portable power bank
Tattu power bank 5200mAh is a USB wall charger and power bank combo. When you're traveling, you no longer need to bring an adapter and charging cable, save your bag space. Meanwhile, power bank 5200mAh compact design and it is easy to carry to everywhere.
Tattu 2in1 power bank can charge up your devices whilst it is being charged. And power will be assigned to the charger and your devices intelligently. It is used wide voltage that can be used every country. Compatible with most mp3, iPad, popular smart phones, such as iPhone, Android cellphone and others.
Specification:
Brand: Tattu
Capacity: 5200mAh
Battery Cell: Lithium-ion
AC Input: AC100V-240V
DC Output: DC5V, 1A+2.4A
Battery output: DC5V,1A+2.4A (In total 3.4Amax)
Overall Dimension: 77*72*22mm
3 Pisen
Pisen 2-in-1 portable charger and wall charger 5000mAh power bank
Pisen is a smart technology provider with long-term experience in electronics production, this power bank built-in foldable AC plug, works as a wall charger as well as a portable charger, compact design, this portable charger boasts a 5000mAh power capacity to power up your devices, featuring a smart 1A/2A input. Easy to take with on flights and travels. It compatible with iPhone, iPad, Android, Tablets, Samsung Galaxy and More.
Specification:
Brand: Pisen
Capacity: 5000mAh
AC Input: 100-240V~0.3A 50-60Hz
Micro USB Input: 5V = 2A
USB Output: 5V = 2A (smart)
Weighs 6.3 oz
