Samsung Galaxy S — Charging problems
  • Closed
Carl Thompson
Dec 29, 2017, 4:25:18 PM via Website
I used a friends charge to charge my s5, when I got home and tried to use my charge and 4 different chargers it would not charge. The only way it will charge now is via usb connected to my pc. Anyone have this problem and know how to solve it. I have tried taking battery out and playing with the power switch, I have tried multiple different chargers and ports, I have tried cleaning the charging port and nothing seems to be working. Please assist if possible anyone
Cihan Çakır
raja emazel
Jan 31, 2022, 1:59:35 PM via Website
I faced the same problem. my [mobile charging jack][1] was spoiled. I replace that one, on that it charges speedly. Instead of going to a OEM or original equipment manufacturer, you can try out in 3rd party sies for good offers.
Some of the sites are maxbhi, xfurbish.com amazon
florajones
Jul 29, 2023, 4:02:56 PM via Website
The same issue happened with my Samsung Galaxy 5 yesterday when I was reading an article about tattoo designs. I tried the different solutions, but nothing worked. I am also looking for a solution.
wextio
  • Forum posts: 150
Jul 31, 2023, 5:19:44 AM via Website
Try a different charging adapter. If you have multiple charging adapters, try using a different one to see if that works.
Reset your phone. This may fix any software problems causing the charging port to malfunction.
— modified on Jul 31, 2023, 5:22:09 AM
https://pathedits.com/blogs/tips
Farwa Cs
Dec 23, 2023, 5:51:45 AM via Website
I am also facing the same issue with my Samsung Galaxy 5. Did you find any solution?I am a tattoo artist and mostly use my mobile to connect with my artist community and customers. But when this issue happened, it really stopped my tattooing activities.
Amelia Smith
Jul 22, 2024, 3:33:05 PM via Website
Have you found any solution? Actually, I faced a similar issue when I was reading an article about tattoo artwork on this website:
