LG Optimus L7 II — Storage problem
Arthur St. Clair Marks
Nov 5, 2017, 9:38:16 AM via Website
Hi all,
I own an LG L7 II and cannot find a way to store/transfer videos to the memory card. Only photos goes to memory card. Can someone please assist and or advise. The fone's memory is a lousy 1.78GB.
Many thanks,
Arthur
tony williams
  • Forum posts: 47
Nov 5, 2017, 4:41:42 PM via Website
Hi what android version are you using ? Go to settings, storage and select use SD card for storing data instead of phone if you can
James Watson
  • Forum posts: 1,605
Nov 6, 2017, 2:38:50 AM via Website
tony williams
As Arthur said "Only photos goes to memory card", I don't think his SD card can't store any data.
Is it possible that free space of the SD card is too small to store big files such as some videos?
Rachael Alice
  • Forum posts: 162
Nov 6, 2017, 6:06:48 AM via Website
I don't think the problem is with SD card and if it is I would recommend you to clear your SD card storage once and then reboot your phone also to see if things are working properly or not.
https://play.google.com/store/apps/details?id=com.autostamper.datetimestampphoto&hl=en
AayK
  • Forum posts: 44
Nov 8, 2017, 9:00:47 AM via Website
Try another sd card, transfer some videos to it, if operation successful it means the previous sd card has an issue, maybe low storage.
Jeromy Tailor
  • Forum posts: 14
Nov 12, 2017, 2:55:27 AM via Website
Never try LG 7 so far. So no suggestion about this one. How it works.
