RE: How to Fix Water Damaged Phone?
Justin Jones
  • Forum posts: 13
Feb 14, 2017, 4:07:15 AM via Website
Turn the wet phone off immediately. Then, wipe it clear and dry it out with a hairdryer (not too close). After that, put it in a bowl of uncooked rice (rice is able to absort water).
James Watson
Sundarsun 2527
  • Forum posts: 39
Feb 16, 2017, 10:33:15 AM via Website
Use hair dryer to dry your interior parts of your mobile, the use some spray to clean the surface. Thats it
James Watson
  • Forum posts: 1,607
Feb 17, 2017, 7:26:33 AM via Website
Yes, turn the wet phone off immediately. It's very important.
Moral Dikson
  • Forum posts: 8
Feb 17, 2017, 9:55:31 AM via Website
Go ask help from professionals.
elentatalo
  • Forum posts: 12
Feb 17, 2017, 9:57:26 AM via Website
To some extends helpful, hope no need to try it
Yerimia ,
  • Forum posts: 4
Feb 18, 2017, 10:06:57 AM via Website
turn off the wet phone. then, wipe with some rag cloth until dry and pray.
Kulwinder Singh
  • Forum posts: 5
Feb 19, 2017, 1:02:58 PM via Website
try to dry it with hair dyrer but don;t do too much heat
elentatalo
  • Forum posts: 12
Feb 21, 2017, 8:57:53 AM via Website
Act quickly. Dry it first.
elentatalo
  • Forum posts: 12
Feb 21, 2017, 9:02:42 AM via Website
1.Do not turn it on
2.Do not press any buttons or keys
3.Do not shake, tap or bang the phone
4.Do not take the phone apart. Your device comes with a Liquid Damage Indicator (LDI) which, when activated, could void your warranty, and this could be triggered when you open your phone. Only take it apart if you absolutely need to and you have experience
5.Do not blow on it. This could send water into other internal parts of the phone that it hadn't already reached, causing more damage in the process
6.Do not heat it up (that includes using a blow dryer or microwaving it)
https://www.nextpit.com/how-to-fix-smartphone-dropped-in-water
Vernie Rasnick
  • Forum posts: 15
Mar 26, 2017, 8:31:29 AM via Website
If it is still under warranty, go to the service center and have it fixed for free. If not, its better to have it fixed by someone who knows the ins and outs.
Hans Brown
  • Forum posts: 20
Apr 25, 2017, 5:33:44 PM via Website
If the water damage phone turn on with the problem of black screen, you can follow this tutorial to recover your important file from the black screen phone before you send it to be fixed.
— modified on Apr 25, 2017, 7:02:19 PM
