- Forum posts: 124
Nov 21, 2016, 6:04:38 AM via Website
Nov 21, 2016 6:04:38 AM via Website
Hi,
Can anyone suggest me that how can i prevent my battery from early draining issue.
Hi,
Nov 22, 2016, 2:45:40 AM via Website
Nov 22, 2016 2:45:40 AM via Website
see this
https://www.nextpit.com/battery-problems-and-solutions-android
Ready To Help You.
Dec 10, 2016, 11:23:52 AM via Website
Dec 10, 2016 11:23:52 AM via Website
Your device provides options that help you conserve battery power. By customizing these options and turning off features in the background, you can use the device longer between charges:
Turn off the Bluetooth® feature.
Turn off Wi-Fi®.
Turn off the GPS service.
Turn off the mobile data connection.
Turn off auto-syncing of accounts.
Turn off the Smart features.
Turn off Always On Display.
Discontinue use of Live wallpapers.
Decrease the backlight time (timeout settings).
Decrease the brightness of the display, or use automatic brightness.
Power saving mode conserves battery power by limiting CPU performance, reducing screen brightness, and turning off the touch key light and vibration feedback. You can turn on Power saving mode manually, or you can set your device to go into Power saving mode automatically.
Use Ultra power saving mode to switch your device's screen to grayscale and turn off nonessential applications so you get the maximum battery life. Location services, and connectivity features such as Wi-Fi and Bluetooth, will also be turned off in Ultra power saving mode. With Ultra power saving mode turned on, even if you're down to a 10% charge, you can receive calls and texts for up to 24 hours.
