Unroot Help.
Sem K
  • Forum posts: 3
Oct 17, 2016, 5:20:03 PM via Website
I recently tried to root my samsung galaxy s7, now it says "Kernel Is Not Seandroid Enforcing"
I tried to download some Stock Rams with Samsung Galaxy s7 but when i wanted to upload them to my phone with odin it failed....
Heres a pic of how it looks IMG_0601
SamiJulie
  • Forum posts: 21
Nov 25, 2016, 3:34:16 PM via Website
As for your case, you can try this way to flash stock Rom on Galaxy S7/S6/S5 via Odin3. Flashing can be much easier than you once thought with this way. However, before you get started, we strongly suggest that you should back up your Samsung phone, for flashing will wipe your data.
— modified on Nov 25, 2016, 3:34:34 PM
  • Forum posts: 770
Nov 27, 2016, 2:52:58 PM via Website
SamiJulie
As for your case, you can try this way to [flash stock Rom on Galaxy S7/S6/S5 via Odin3][1]. Flashing can be much easier than you once thought with this way. However, before you get started, we strongly suggest that you should back up your Samsung phone, for flashing will wipe your data.
[1]: https://www.recovery-android.com/flash-samsung-stock-rom-odin3.html
This is the best method.
Ready To Help You.
lla dermis
  • Forum posts: 13
Nov 28, 2016, 7:46:53 PM via Website
Great man, i find the solution for my friend's S7
tesss cord
  • Forum posts: 12
Nov 29, 2016, 7:31:37 PM via Website
Good information, ...
