HELP!!! My 16gb internal phone storage segmented into 2 different parts
I_noSc0pedJFK
Oct 9, 2016, 1:26:00 PM via Website
I have mtk device (xolo-8x1000) with 16 GB internal storage
But now somehow it has been divided into 2 parts of 3.94 GB and 9.45 GB
Out of these 2 parts google play store an all other use the 3.94gb partition and the other one remains unused
Screenshot_2016 10 09 16 21 04
Screenshot_2016 10 09 16 20 55
Screenshot_2016 10 09 16 29 08
I cannot find a way to merge those two partitions plz helppp!!
Dennis McCunney
  • Forum posts: 9
Oct 9, 2016, 7:28:51 PM via Website
Can you verify that it wasn't fragmented before? I suspect it was, and came that way.
What you are seeing is likely how the device was designed. Internal flash will be partitioned, and not all of it will be available to store apps. The rest will either be used by Android, or serve as an area to store data. I don't know of a way to merge partitions, and you would need to be rooted to even attempt it.
Xolo says the device has a microSD slot, which gives you a possible option if you can root the phone.
I had a problem with an older tablet that had a whopping 787MB of app storage, which was exhausted simply add standard Google apps. It had a microSD slot, so I got a 32GB microSD card. You can't store apps on a card as delivered. SD cards come formatted as FAT32, and you can only store apps on a Linux filesystem. I put the card into an adapter and repartitioned it from Windows, carving out a 2GB file system formatted as ext4, using a freeware program called Mini-Tool Partition Manager. I put the partitioned card in the tablet, powered off, and rebooted. Android saw a new filesystem on the card and mounted it.
Once it was in place, I could use a freeware app from the Play Store called Link2SD. Link2SD can take an app in internal storage and move it to the ext4 partition on the card, then place a symlink to it in the root file system. Android follows the symlink and runs the app. I was able to install what I wanted on the old tablet because I was no longer limited to internal storage.
See if there's a rooting program for the Xolo that will let you try what I did. If there isn't, I'm afraid you may stuck with the app storage you have and will just have to pick and choose what you really need to stay with device limits.
>Dennis
I_noSc0pedJFK
I_noSc0pedJFK
Oct 10, 2016, 8:44:14 AM via Website
Yes I am sure that it did not come that way
I have also tried the link2sd thing it didn't work
Dennis McCunney
  • Forum posts: 9
Oct 10, 2016, 9:05:05 AM via Website
I'll be very surprised if the 16GB internal storage was not partitioned. I think you just weren't aware of it. I can't think of anything you could do as an ordinary user that would partition it if it hadn't been.
Do you have a rooted device? Link2SD requires root to do what it does. If your device is not rooted, Link2SD can't work.
>Dennis
Christie Rodriguez
  • Forum posts: 70
Oct 10, 2016, 12:31:51 PM via Website
Hi Dennis, this was a great solution for an internal phone storage.
Dennis McCunney
  • Forum posts: 9
Oct 10, 2016, 8:20:18 PM via Website
It's been useful for me.
There's an open source equivalent for Link2SD available in the F-Droid repo called Mounts2SD with a variety of features that is also worth a look. There's a discussion thread on XDA Developers about it
I discovered Link2SD first and it's what I use for the purpose, but it's not the only solution.
>Dennis
Nickybaby
Jan 19, 2017, 4:14:58 AM via Website
you can retrieve data by yourself. There are programs to do that. For example My Device Manager
I used it few times.
But there is a sad news. I'm not sure but most of these programs work with NTFS and FAT32 files systems. I recently tried to find something that would work with ext4 but I was unsuccessful. So, because OS X is using HFS+ file system there could be problem with software. But I can't believe that they don't exist.
To sum up try to google "recovering HFS+ partition" or find program for recovering data that can work with HFS+ file system.
Good luck!
