- Forum posts: 16
Sep 6, 2016, 8:21:31 AM via Website
Sep 6, 2016 8:21:31 AM via Website
Are you worried sbout your mobile battery timing.Then here is the solution A brand new du yellow battery saver & cleaner which gives your mobile battery a new life and save him from caches also.
Yellow battery saver and cleaner is a Dr for your smartphone cleanup the Bacteria of your smartphone,it can also boost up your mobile and cleanup the disks and ram of your mobile.Yellow battery saver & cleaner is a life saver for your mobile which manage your mobile apps and utilities which you never ever want to uninstall from your mobile,and also improve the battery life and more others.
Yellow battery saver & cleaner is a booster application at play store which gives you tips to manage the utility apps,clean up your cache and memory through this,even also wifi checker manager of your mobile which inform you about your battery health and give them more improvements according to his mananger.
Yellow battery saver & cleaner manager is one of the best docter saver app boost up your mobile and give tips to you that how you cn charge your mbile & during charging it can give you two types of modes where you get it and use it in this app.
Yellow battery saver & cleaner management is widget power app which save your memories and disks also
Yellow battery saver and cleaner features:
Provide you the status of battery
Four types of saver modes
Cache cleaner manager
Simple user interface
Realistic graphics
