- Forum posts: 15
Aug 11, 2016, 2:13:15 PM via Website
Aug 11, 2016 2:13:15 PM via Website
How can I block a call from a particular number?
Aug 12, 2016, 4:38:23 PM via Website
Aug 12, 2016 4:38:23 PM via Website
I use a program called Should I Answer. It usually blocks calls before I even hear it ring. It blocks a lot of robocalls, you can also add specific numbers you don't want to hear from anymore.
Aug 14, 2016, 10:49:41 AM via Website
Aug 14, 2016 10:49:41 AM via Website
Is this an app that you can get from the Google Play Store or do you have to install it a different way?
Aug 14, 2016, 2:36:44 PM via Website
Aug 14, 2016 2:36:44 PM via Website
try this app. It also includes call recorder Call Manager
Aug 14, 2016, 3:36:51 PM via Website
Aug 14, 2016 3:36:51 PM via Website
Should I Answer Is a program in playstore. The icon looks like an octopus
Aug 15, 2016, 5:12:07 PM via Website
Aug 15, 2016 5:12:07 PM via Website
it is possible to do this without having to install any software?
Aug 15, 2016, 5:34:36 PM via Website
Aug 15, 2016 5:34:36 PM via Website
You could always add that number to your contacts and change the custom ring tone to silent. That way you won't hear it.
Aug 15, 2016, 7:27:23 PM via Website
Aug 15, 2016 7:27:23 PM via Website
Chris
yes. Some phone have call blocking in Call settings
Aug 16, 2016, 11:02:17 AM via Website
Aug 16, 2016 11:02:17 AM via Website
I will look for
Aug 16, 2016, 12:16:30 PM via Website
Aug 16, 2016 12:16:30 PM via Website
Contact customer support soon. Hope they will help you to block a particular number which you don't want receive.
Aug 17, 2016, 1:01:11 PM via Website
Aug 17, 2016 1:01:11 PM via Website
thankx
Aug 17, 2016, 1:01:37 PM via Website
Aug 17, 2016 1:01:37 PM via Website
Yes you said that right
Aug 17, 2016, 8:40:27 PM via Website
Aug 17, 2016 8:40:27 PM via Website
thanks for information
Sep 3, 2016, 9:22:04 AM via Website
Sep 3, 2016 9:22:04 AM via Website
There must be an option in your mobile phone, otherwise you can find app from google play store if you are using an android phone. Some app also provide extra features like call recording.
Oct 10, 2016, 6:53:09 AM via Website
Oct 10, 2016 6:53:09 AM via Website
I utilize a program called Should I Answer. It for the most part squares calls before I even hear it ring. It obstructs a considerable measure of robocalls, you can likewise include particular numbers you would prefer not to get notification from any longer.
