- Forum posts: 12
Jun 30, 2016, 9:49:50 AM via Website
Jun 30, 2016 9:49:50 AM via Website
More FREE! games for iOS and Android : www.themascoteers.com/our-games
Things to consider before you try the new Tunnel addictive game
Tips:
For the shooting objects you have to be very careful, because they appear all of a sudden. Therefore, being extra cautious is the key to long survival.
If you attempt to save yourself from the obstacles and also attempt to grab the coins, you might get yourself killed. Save yourself first, then attempt for the coins.
The hardest part of the game is probably the narrow paths. When you get spiral narrow path, tap and hold to get through the spiral. When you get e straight narrow path, don’t hold for too long, don’t release for too long, just keep on going by slight continuous tap and hold.
Good luck and hope you have a good time in our flashy tunnel!!
