- Forum posts: 1
May 21, 2016, 2:52:21 PM via Website
May 21, 2016 2:52:21 PM via Website
I am trying to build an app that tracks the route some one is running. I am using google api for this and it is working good also adding polylines to the map is working as it should but i am not getting any location updates for some reason. I have been on this for a week now and i need some extra help.
import android.app.AlertDialog;
import android.content.Context;
import android.content.DialogInterface;
import android.content.Intent;
import android.content.IntentSender;
import android.content.SharedPreferences;
import android.content.pm.PackageManager;
import android.graphics.Color;
import android.location.Criteria;
import android.location.Location;
import android.location.LocationManager;
import android.os.Bundle;
import android.os.IBinder;
import android.support.annotation.Nullable;
import android.support.v4.app.Fragment;
import android.support.v4.app.FragmentManager;
import android.support.v4.content.ContextCompat;
import android.support.v4.widget.DrawerLayout;
import android.util.Log;
import android.view.LayoutInflater;
import android.view.View;
import android.view.ViewGroup;
import android.widget.Button;
import android.widget.ImageView;
import android.widget.LinearLayout;
import android.widget.TextView;
import com.google.android.gms.common.ConnectionResult;
import com.google.android.gms.common.api.GoogleApiClient;
import com.google.android.gms.location.LocationListener;
import com.google.android.gms.location.LocationRequest;
import com.google.android.gms.location.LocationServices;
import com.google.android.gms.maps.CameraUpdateFactory;
import com.google.android.gms.maps.GoogleMap;
import com.google.android.gms.maps.SupportMapFragment;
import com.google.android.gms.maps.model.LatLng;
import com.google.android.gms.maps.CameraUpdate;
import com.google.android.gms.maps.MapView;
import com.google.android.gms.maps.MapsInitializer;
import com.google.android.gms.maps.OnMapReadyCallback;
import com.google.android.gms.maps.model.PolylineOptions;
import com.squareup.picasso.Picasso;
import java.math.BigDecimal;
import java.util.ArrayList;
/** * Created by gebruiker on 19-05-16. */public class WorkoutActivity extends Fragment implements OnMapReadyCallback, GoogleApiClient.ConnectionCallbacks,
GoogleApiClient.OnConnectionFailedListener, LocationListener {
private static String TAG = WorkoutActivity.class.getSimpleName();
private final static int CONNECTION_FAILURE_RESOLUTION_REQUEST = 9000;
LocationRequest mLocationRequest;
MapView mapView;
GoogleMap map;
private GoogleApiClient mGoogleApiClient;
private SharedPreferences preferenceSettings;
private SharedPreferences.Editor preferenceEditor;
private static final int PREFERENCE_MODE_PRIVATE = 0;
private static final String PREF_NAME = "UserDetails";
public static final String POST_USEREMAIL = "username";
MainActivity mainactivity;
String emailUser, workoutType, provider;
Button stopWorkout, startWorkout;
TextView speed, info;
ImageView workoutImage;
LinearLayout mapLayout, startWorkoutLayout;
Double currentLat, currentLong;
Double Lat, Longi;
String latLong = "No Location Found!!!";
protected LocationManager locationManager;
final private int REQUEST_CODE_ASK_PERMISSIONS = 123;
//counter that is incremented every time a new position is received, used to calculate average speedint counter = 0;
//objects to store values for current and average speedprotected double currentSpeed;
protected double kmphSpeed;
protected double avgSpeed;
protected double avgKmph;
protected double totalSpeed;
protected double totalKmph;
ArrayList polylines;
@Overridepublic void onCreate(Bundle savedInstanceState) {
super.onCreate(savedInstanceState);
preferenceSettings = this.getActivity().getSharedPreferences(PREF_NAME, PREFERENCE_MODE_PRIVATE);
preferenceEditor = preferenceSettings.edit();
emailUser = preferenceSettings.getString("Email", null);
Log.d("Saved user email:", "" + emailUser);
Bundle bundle = this.getArguments();
if (bundle != null) {
workoutType = bundle.getString("workoutType");
mGoogleApiClient = new GoogleApiClient.Builder(getActivity())
.addConnectionCallbacks(this)
.addOnConnectionFailedListener(this)
.addApi(LocationServices.API)
.build();
// Create the LocationRequest objectmLocationRequest = LocationRequest.create()
.setPriority(LocationRequest.PRIORITY_HIGH_ACCURACY)
.setInterval(1 * 1000) // 5 seconds, in milliseconds.setFastestInterval(1 * 1000); // 1 second, in milliseconds}
@Overridepublic View onCreateView(LayoutInflater inflater, ViewGroup container, Bundle savedInstanceState) {
View view = inflater.inflate(R.layout.activity_workout, container, false);
mapView = (MapView) view.findViewById(R.id.mapview);
stopWorkout = (Button) view.findViewById(R.id.stopWorkout);
startWorkout = (Button) view.findViewById(R.id.startWorkout);
startWorkoutLayout = (LinearLayout) view.findViewById(R.id.startWorkoutLayout);
mapLayout = (LinearLayout) view.findViewById(R.id.mapLayout);
workoutImage = (ImageView) view.findViewById(R.id.workoutImage);
speed = (TextView) view.findViewById(R.id.speed);
info = (TextView) view.findViewById(R.id.info);
mapView.onCreate(savedInstanceState);
mainactivity = (MainActivity )getActivity();
mainactivity.menuButton.setVisibility(View.GONE);
mainactivity.mDrawerLayout.setDrawerLockMode(DrawerLayout.LOCK_MODE_LOCKED_CLOSED);
mainactivity.pageTitle.setText("Workout");
mapLayout.setVisibility(View.GONE);
polylines = new ArrayList();
// Gets to GoogleMap from the MapView and does initialization stuffmap = mapView.getMap();
map.getUiSettings().setMyLocationButtonEnabled(false);
map.setMyLocationEnabled(true);
// Needs to call MapsInitializer before doing any CameraUpdateFactory callsMapsInitializer.initialize(this.getActivity());
stopWorkout.setOnClickListener(new View.OnClickListener() {
@Overridepublic void onClick(View v) {
selectOption();
workoutType = "walking";
startWorkout.setOnClickListener(new View.OnClickListener() {
mapLayout.setVisibility(View.VISIBLE);
startWorkoutLayout.setVisibility(View.GONE);
if(workoutType.matches("running")){
Picasso.with(this.getActivity())
.load(R.drawable.newrun)
.fit()
.centerCrop()
.into(workoutImage);
if(workoutType.matches("cycling")){
.load(R.drawable.newcycling)
.fit()
.centerCrop()
if(workoutType.matches("walking")){
.load(R.drawable.newwalk)
.fit()
.centerCrop()
return view;
@Overridepublic void onDestroy() {
super.onDestroy();
mainactivity.mDrawerLayout.setDrawerLockMode(DrawerLayout.LOCK_MODE_UNLOCKED);
if (mGoogleApiClient.isConnected()) {
LocationServices.FusedLocationApi.removeLocationUpdates(mGoogleApiClient, this);
mGoogleApiClient.disconnect();
@Overridepublic void onLowMemory() {
super.onLowMemory();
mapView.onLowMemory();
@Overridepublic void onResume() {
super.onResume();
setUpMapIfNeeded();
mapView.onResume();
mGoogleApiClient.connect();
@Overridepublic void onPause() {
super.onPause();
@Overridepublic void onMapReady(GoogleMap googleMap) {
//DO WHATEVER YOU WANT WITH GOOGLEMAPmap.setMapType(GoogleMap.MAP_TYPE_HYBRID);
map.setMyLocationEnabled(false);
map.setTrafficEnabled(false);
map.setIndoorEnabled(true);
map.setBuildingsEnabled(true);
map.getUiSettings().setZoomControlsEnabled(true);
@Overridepublic void onLocationChanged(Location location) {
// TODO Auto-generated method stubLog.d(TAG, "Location update running");
handleNewLocation(location);
public void selectOption() {
final CharSequence[] items = { "Workout Opslaan", "Afbreken", "Sluiten" };
AlertDialog.Builder builder = new AlertDialog.Builder(WorkoutActivity.this.getActivity());
builder.setTitle("Workout opties");
builder.setItems(items, new DialogInterface.OnClickListener() {
@Overridepublic void onClick(DialogInterface dialog, int item) {
if (items[item].equals("Workout Opslaan")) {
} else if (items[item].equals("Afbreken")) {
mapView.onDestroy();
mainactivity.menuButton.setVisibility(View.VISIBLE);
onDestroy();
Fragment fragment = new HomePage();
// Insert the fragment by replacing any existing fragmentFragmentManager fragmentManager = getFragmentManager();
fragmentManager.beginTransaction()
.replace(R.id.mainContent, fragment)
.commit();
} else if (items[item].equals("Sluiten")) {
dialog.dismiss();
builder.show();
@Overridepublic void onConnected(@Nullable Bundle bundle) {
Log.i(TAG, "Location services connected.");
Location location = LocationServices.FusedLocationApi.getLastLocation(mGoogleApiClient);
if (location == null) {
Log.i(TAG, "Location connecting.");
if (ContextCompat.checkSelfPermission(getActivity(), android.Manifest.permission.ACCESS_FINE_LOCATION)
== PackageManager.PERMISSION_GRANTED) {
LocationServices.FusedLocationApi.requestLocationUpdates(mGoogleApiClient, mLocationRequest, this);
}else {
requestPermissions(new String[]{android.Manifest.permission.ACCESS_FINE_LOCATION}, 0);
else {
Log.i(TAG, "Running new location update");
@Overridepublic void onConnectionSuspended(int i) {
Log.i(TAG, "Location services suspended. Please reconnect.");
@Overridepublic void onConnectionFailed(ConnectionResult connectionResult) {
if (connectionResult.hasResolution()) {
try {
// Start an Activity that tries to resolve the errorconnectionResult.startResolutionForResult(this.getActivity(), CONNECTION_FAILURE_RESOLUTION_REQUEST);
} catch (IntentSender.SendIntentException e) {
e.printStackTrace();
} else {
Log.i(TAG, "Location services connection failed with code " + connectionResult.getErrorCode());
private void handleNewLocation(Location location) {
Log.d(TAG, location.toString());
double currentLatitude = location.getLatitude();
double currentLongitude = location.getLongitude();
Lat = location.getLatitude();
Longi = location.getLongitude();
LatLng latLng = new LatLng(currentLatitude, currentLongitude);
CameraUpdate zoom=CameraUpdateFactory.zoomTo(17);
map.moveCamera(CameraUpdateFactory.newLatLng(latLng));
map.animateCamera(zoom);
counter++;
//current speed of the gps devicecurrentSpeed = round(location.getSpeed(),3, BigDecimal.ROUND_HALF_UP);
kmphSpeed = round((currentSpeed*3.6),3,BigDecimal.ROUND_HALF_UP);
//all speeds added togethertotalSpeed = totalSpeed + currentSpeed;
totalKmph = totalKmph + kmphSpeed;
//calculates average speedavgSpeed = round(totalSpeed/counter,3,BigDecimal.ROUND_HALF_UP);
avgKmph = round(totalKmph/counter,3,BigDecimal.ROUND_HALF_UP);
//gets positioncurrentLatitude = round(((double) (location.getLatitude())),3,BigDecimal.ROUND_HALF_UP);
currentLongitude = round(((double) (location.getLongitude())),3,BigDecimal.ROUND_HALF_UP);
String infoDetails = "Afstand: "+" | Tijd: ";
String updateSpeed = String.valueOf(kmphSpeed);
Log.d(TAG, updateSpeed.toString());
//info.setText();speed.setText("Snelheid: "+updateSpeed+" km/hr");
buildPolyline();
//Method to round the doubles to a max of 3 decimal placespublic static double round(double unrounded, int precision, int roundingMode)
BigDecimal bd = new BigDecimal(unrounded);
BigDecimal rounded = bd.setScale(precision, roundingMode);
return rounded.doubleValue();
public void buildPolyline(){
Log.d(TAG,"Adding polyline" );
LatLng polyline;
polyline = new LatLng(Lat, Longi);
polylines.add(polyline);
Log.d("Locations Array", ""+polylines);
map.addPolyline(new PolylineOptions().addAll(polylines).width(6.0f).color(Color.BLUE));
//map.moveCamera(CameraUpdateFactory.newLatLngZoom(Start, 14));}
private void setUpMapIfNeeded() {
// Do a null check to confirm that we have not already instantiated the map.if (map == null) {
// Try to obtain the map from the SupportMapFragment.map = ((SupportMapFragment) getActivity().getSupportFragmentManager().findFragmentById(R.id.mapview))
.getMap();
// Check if we were successful in obtaining the map.if (map != null) {
I have a location manager but it seems it is just not running. I only get a new update then i dismiss the app and turn it back on.
I hope someone can help me with this, i am really stuck.
