Memory card problem
Sayon Roy
  • Forum posts: 10
Dec 22, 2015, 11:33:02 AM via Website
Hi all...
I have a 32GB samsung microsd card.
After inserting it, it seems like normal.. But if i copy videos or songs it doesnt play! After copying its corrupt by uuuuuuuuuuu like this thing.. I dont know whats the problem with this.. I can format it.. But cant use it! Is it read write problem? Cant store apps in this.. When i check uc mini.. There when changing storage location it shows, 'by android policy folder will be removed if uc uninstalled'
Sayon Roy
  • Forum posts: 10
Dec 22, 2015, 11:39:54 AM via Website
& to be sure i copy some song to sd card via usb in my lappy.. Then restart my phone.. Then again i cant play via any video player.. I connect to lappy again & tried to play from sd card via km player.. It doest play & in kmplayer also it shows uuuuuuuuuuuuuuuuu like this.. Help me to solve this problem
nilofar shaikh
  • Forum posts: 581
Dec 23, 2015, 2:27:54 PM via Website
How old is your memory card? sounds like it is corrupted.
DroidMaker
  • Forum posts: 23
Dec 23, 2015, 3:25:05 PM via Website
i might be infected by some kind of virus try scanning it if it doesn't help then the card is corrupted
Sayon Roy
  • Forum posts: 10
Dec 24, 2015, 6:15:10 AM via Website
Noh its new.. Problem is when i format it in ntfs it works fine in lappy.. But fat32 in android doesnt allow to read write i think.. I tries platform.xml file editing. But no luck.. Is ther a way to use it as ntfs in my android permanently.. If yes then how?
Sayon Roy
  • Forum posts: 10
Dec 24, 2015, 6:30:40 AM via Website
I chkd with CMD >chkdsk...no problem there.. ?
