Best power bank for android smartphone?
Allen He
Sep 15, 2015, 4:46:13 AM via Website
i like playing mobile games like ingress but my phone always lack of power i want a high capacity and light weight power bank to charging my phone all the time.
Penny Yangdamponting44
Jack
Feb 13, 2016, 4:16:41 AM via Website
Zendure is best power bank in all devices . This is very good product . Some time ago, I have same problem and I am very confuse then I choose this product . Battery power is awesome and portable charger ,at a time 4 devices charger .
Himanshu Gupta
Apr 14, 2016, 9:08:28 PM via Website
If you are looking for the best power banks to buy make sure to check out the post below.
It lists out the best power banks with its specs and advantages.
Link:-bestpowerbanksindia.in/best-power-banks-for-mobile-in-india/
damponting44
Henry Android Studio
  • Forum posts: 4
Apr 20, 2016, 3:15:27 PM via Website
Definitely is Xiaomi Powerband. its good quality powerband with lower price tag
damponting44
Uimi Technologies
May 20, 2016, 12:20:01 PM via Website
if want to resolve your issues like charging problems dont worry about it go with our UIMI power banks with 10400 mah battery
Kwan S.
  • Forum posts: 13
May 20, 2016, 1:52:04 PM via Website
Hello Allen He,
You should try Lenovo Power bank of 10400 MAh. pretty good.
damponting44
pentel
  • Forum posts: 251
May 20, 2016, 6:48:40 PM via Website
You can check out the Aukey powerbanks from Amazon. They come in 20000mAh, 15000mAh, 12000mAh, 10000mAh, 5000mAh, etc.
damponting44
Tanvi Yadav
Jun 4, 2016, 2:10:24 PM via Website
Hi,
I used to face same problem earlier so I opted to buy an advent 2600 mAh power bank, and it has been working really well for me so far. I had bought it from Hi2Buy. It is very light weight and very compact so I can easily carry it in my purse. It also comes with a security multilayer protection against overcharge thereby making it safer and also prevents any damage to the power bank. Overall I am really happy with the product.
Rahul Pahwa
  • Forum posts: 22
Jun 4, 2016, 2:25:49 PM via Website
you can get oneplus power bank it is really great.......
Supriya Jagtap
  • Forum posts: 3
Jun 18, 2016, 7:18:41 PM via Website
I am a tech blogger and I have reviewed almost 50 power banks for my blog on Best Power Bank. I can tell you few power banks brands which are trusted and have very nice quality battery cells.
  1. Anker
  2. Eassyacc
  3. Limefuel
  4. Xiaomi
You can also read detailed guide on how to choose your kind of power bank on my blog feel free to ask me !!
Thank you very much !
damponting44
  • Forum posts: 70
Oct 10, 2016, 7:00:41 AM via Website
Zendure is best power bank in all gadgets . This is great item . Some time prior, I have same issue and I am exceptionally confound then I pick this item . Battery power is marvelous and convenient charger ,at once 4 gadgets charger .
Brain Chris
Nov 18, 2016, 12:06:39 PM via Website
Glad to know that you're a gammer! I like playing games too!
So my suggestion regarding your mobile battery is to use power bank portable charger.
It's easy to carry due to light weight and it'll also work as your travel partner to supply power!
grab it on: brandedbatteries.com
Have a blessed day!
Cheers!
Brain
Topapps4u
  • Forum posts: 124
Nov 18, 2016, 1:14:42 PM via Website
EasyAcc 10000mAh Ultra Slim Dual USB Portable Power Bank
Ava brewer
Nov 18, 2016, 3:36:14 PM via Website
for me the more Ah the better, but quality is a good choice too.. I use it when I test my china web design apps in my tab.
Supriya Jagtap
  • Forum posts: 3
Feb 2, 2017, 6:19:23 PM via Website
Hello Allen,
I am a professional blogger and I had reviewed many power banks myself.
I would like to suggest you some best power banks for your need
As you are gamer you will need a power bank which can be charged while you are using it to charge your phone too.
This is called pass through charging almost all new power banks has this technology
Here are some :
1 Anker power core
2 Eassyacc
3 Ravpower
4 Xiaomi 20000 mah
Alway try to compare your mobiles battery and power bank capacity which would help you to select appropriate power bank
Thank you
Here is source and detailed review www.powerbanktalk.com/best-portable-power-bank-review-2015
martin smith
  • Forum posts: 277
Feb 3, 2017, 2:21:46 PM via Website
one plus power bank is really good....
IT Blog
Saumya Jain
Feb 11, 2017, 8:21:28 AM via Website
COOLNUT [Power Bank 20000mAh][1] is Best solution for your Mobile Phone. You can charge up to 4-5 times to your smartphone without any has sale .This Power Bank is stylish looking and easy to carry .
This Power Bank is available at Amazon India .
Dhaval12
  • Forum posts: 3
Mar 4, 2017, 8:23:07 AM via Website
Hello Allen,
Xiaomi 10,400 mAh power Bank is the Best for your Android phone. you should try this power bank.
Penny Yang
  • Forum posts: 3
Apr 19, 2017, 11:19:43 AM via Website
Allen He
Model P65 will be a good choice.
15600mah, 92% conversation , charging iphones (5-6times)
Rahul
May 23, 2017, 7:42:37 AM via Website
Hey Allen,
I am Rahul, I was facing the same issues while I was using Moto G4 plus, after 6 months my phone started getting overheat and battery got draining issues. I found the link where they update best power banks.
Steve D.
  • Forum posts: 11
May 23, 2017, 8:37:02 AM via Website
As per my own uses, I will recommend to use MI power bank, I am using Mi power bank last 4 months. I can 3 times charge my mobile with using Mi power bank.
baharhashemi75
Sohie
  • Forum posts: 5
Sep 4, 2017, 9:13:34 AM via Website
I recommend xiaomi and Tattu power bank, they all charge some times per charge.
baharhashemi75Sorin
Penny Yang
  • Forum posts: 3
Jan 5, 2018, 11:32:35 AM via Website
Hi Allen,
You may try 20000mah power bank, P65 good one for your refernce.
charging phones about more than 7 times.
P65 A__5
Sorin
Penny Yang
  • Forum posts: 3
Jan 5, 2018, 11:33:54 AM via Website
P65 from Volpower , can charge mobiles with more than 7 times.
You may try it , also can charge your PC
P65__7
Sorin
Sohie
  • Forum posts: 5
Mar 8, 2018, 9:09:26 AM via Website
Hmm...Good power bank, but it looks like bigger and heavier. I like the compact size, easy to carry. Anker 5000mAh power bank and Tattu 2-in-1 5200mAh power bank are suited my mind. They are all multi-function power bank (wall charger+power bank). But now, I don't know which one to choose?
Sorin
Acid Eye
Apr 18, 2018, 10:02:13 AM via Website
Acid Eye Universal Charging 15000 mAh Power Bank Metal body (Black, 15000 mAh). I am using this power bank from last 3 years and i am not getting any problems till present.
So you can Buy from : Amazon
Anon Y Mous
  • Forum posts: 7
Jan 10, 2019, 2:31:48 PM via Website
I personally use this:
ZMI PowerPack 10,000mAh Battery Pack Fast Charging Portable Charger
(The forum won't let me post an actual link, but it looks like "amazon dot com/gp/product/B077QCG1WP" )
I've recharged my phone three times on one night charge-up. It comes with a standard USB-microUSB cord; if you need a different charging connector for your phone (like for an iPhone), you'll have to buy that separate.
alice434
  • Forum posts: 13
Mar 4, 2019, 10:36:13 AM via Website
Thanks for the information.
Mark Deutsch
  • Forum posts: 27
May 11, 2019, 9:06:12 AM via Website
This is generally amazing item . Some time back, I have same issue and I am very confound then I pick this item . Battery control is wonderful and versatile charger ,at once 4 gadgets charger .
baharhashemi75
Jul 17, 2019, 1:18:29 PM via Website
hi sohie
i have a Tsco TP 876L; i think Tsco power bank TP 876L is very amazing...
Tsco products are high quality
TP 876L 20000ml is wonderful power bank. best design and excellent Capacity! I am very pleased with it
nitesh
Jul 29, 2019, 11:30:40 AM via Website
Try this website which has the best articles information for power bank
www.uberdecors.com/best-power-bank-in-india/
saraomidi
  • Forum posts: 4
Aug 8, 2019, 12:04:51 PM via Website
hi bahar...
i think xiaomi power banks is the best..
xiaomi products is one of the best products in the world. xiaomi power bank 2c 20000 is excellent.. i really like this and use it..
