- Forum posts: 1
Jun 2, 2015, 2:37:52 PM via Website
Jun 2, 2015 2:37:52 PM via Website
I writing audio from microphone to mp4 (aac audio). I get audio raw data from Microphone by AudioRecord and send to MediaCodec. After that I send the audio data to MediaMux to get a mp4 file. I have problem: then my application record audio in background service and user does something with device (to navigate in menu or use other application), result audio record have troubles (faster playback, pauses).
[enter link description here][1]
public void run() {
if (mIsInitialized) {
switch (type) {
case ENCODE_AUDIO_FRAME:
if (!mStopReceived) {
_offerAudioEncoder(mAudioData, presentationTimeNs);
processAudioFrame();
break;
// prevent multiple execution of same task
mIsInitialized = false;
mEncodingServiceQueueLength -= 1;
} else {
Log.e(TAG, "run() called but EncoderTask not initialized");
private void _offerAudioEncoder(byte[] input, long presentationTimeNs) {
if (audioBytesReceived == 0) {
mAudioStartTime = presentationTimeNs;
mTotalInputAudioFrameCount++;
audioBytesReceived += input.length;
if (mEosSentToAudioEncoder && mStopReceived || input == null) {
logStatistics();
if (mEosReceived) {
Log.d(TAG, "EOS received in offerAudioEncoder");
closeAudioEncoder();
mEosSentToAudioEncoder = true;
prepareAudioEncoder();
} else {
mEncodingService.shutdown();
return;
// transfer previously encoded data to muxer
drainEncoder(mAudioEncoder, mAudioBufferInfo, mAudioTrackIndex, false, "audio");
try {
ByteBuffer[] inputBuffers = mAudioEncoder.getInputBuffers();
int inputBufferIndex = mAudioEncoder.dequeueInputBuffer(-1);
if (inputBufferIndex >= 0) {
ByteBuffer inputBuffer = inputBuffers[inputBufferIndex];
inputBuffer.clear();
inputBuffer.put(input);
if (mAudioSoftwarePoller != null) {
mAudioSoftwarePoller.recycleInputBuffer(input);
long presentationTimeUs = (presentationTimeNs - mAudioStartTime) / 1000; // in microseconds
if (mEosReceived) {
mAudioEncoder.queueInputBuffer(inputBufferIndex, 0, input.length, presentationTimeUs, MediaCodec.BUFFER_FLAG_END_OF_STREAM);
if (mStopReceived) {
} else {
mAudioEncoder.queueInputBuffer(inputBufferIndex, 0, input.length, presentationTimeUs, 0);
} catch (Throwable t) {
t.printStackTrace();
private void drainEncoder(MediaCodec encoder, MediaCodec.BufferInfo bufferInfo, TrackIndex trackIndex, boolean endOfStream, String type) {
int TIMEOUT_USEC = 100;
ByteBuffer[] encoderOutputBuffers = encoder.getOutputBuffers();
while (true) {
int encoderStatus = encoder.dequeueOutputBuffer(bufferInfo, TIMEOUT_USEC);
if (encoderStatus == MediaCodec.INFO_TRY_AGAIN_LATER) {
if (!endOfStream) {
if (VERBOSE) Log.d(TAG, "INFO_TRY_AGAIN_LATER " + type + " out of while");
break; // out of while
} else {
if (VERBOSE) Log.d(TAG, "no " + type + " output available, spinning to await EOS");
} else if (encoderStatus == MediaCodec.INFO_OUTPUT_BUFFERS_CHANGED) {
// not expected for an encoder
if (VERBOSE) Log.d(TAG, "INFO_OUTPUT_BUFFERS_CHANGED " + type);
} else if (encoderStatus == MediaCodec.INFO_OUTPUT_FORMAT_CHANGED) {
// should happen before receiving buffers, and should only happen once
if (mMuxerStarted) {
throw new RuntimeException("format changed after muxer start");
MediaFormat newFormat = encoder.getOutputFormat();
Log.d(TAG, "encoder output format changed: " + newFormat + ".");
// now that we have the Magic Goodies, start the muxer
synchronized (mMuxer) {
trackIndex.index = mMuxer.addTrack(newFormat);
numTracksAdded++;
Log.d(TAG, "Added " + type + " track index: " + trackIndex.index);
if (numTracksAdded == TOTAL_NUM_TRACKS) {
mMuxer.start();
mMuxerStarted = true;
Log.d(TAG, numTracksAdded + " tracks added. Muxer started");
break;
} else if (encoderStatus < 0) {
Log.w(TAG, "unexpected result from " + type + " encoder.dequeueOutputBuffer: " +
encoderStatus);
} else {
if (encodedData == null) {
if (VERBOSE) Log.d(TAG, "drainEncoder(" + endOfStream + ") " + type + " encodedData == null");
throw new RuntimeException("encoderOutputBuffer " + encoderStatus +
" was null");
if ((bufferInfo.flags & MediaCodec.BUFFER_FLAG_CODEC_CONFIG) != 0) {
// The codec config data was pulled out and fed to the muxer when we got
// the INFO_OUTPUT_FORMAT_CHANGED status. Ignore it.
if (VERBOSE) Log.d(TAG, "ignoring BUFFER_FLAG_CODEC_CONFIG");
bufferInfo.size = 0;
if (bufferInfo.size != 0) {
if (!mMuxerStarted) {
if (VERBOSE) Log.d(TAG, "drainEncoder(" + endOfStream + ") " + type + " Muxer not started");
throw new RuntimeException("muxer hasn't started");
// adjust the ByteBuffer values to match BufferInfo (not needed?)
encodedData.position(bufferInfo.offset);
encodedData.limit(bufferInfo.offset + bufferInfo.size);
mMuxer.writeSampleData(trackIndex.index, encodedData, bufferInfo);
encoder.releaseOutputBuffer(encoderStatus, false);
if ((bufferInfo.flags & MediaCodec.BUFFER_FLAG_END_OF_STREAM) != 0) {
if (!endOfStream) {
Log.w(TAG, "reached end of stream unexpectedly");
} else {
if (VERBOSE) Log.d(TAG, "end of stream reached");
break;
long endTime = System.nanoTime();
public void processAudioFrame() {
long audioPresentationTimeNs = System.nanoTime();
byte[] thisBuffer;
if (mDataBuffer.isEmpty()) {
thisBuffer = new byte[mSamplesPerFrame];
} else {
thisBuffer = mDataBuffer.poll();
mReadResult = mAudioRecorder.read(thisBuffer, 0, mSamplesPerFrame);
if (VERBOSE) Log.i(TAG, "FillBuffer real: " + String.valueOf(mBufferWriteIndex)
+ " - " + String.valueOf(mBufferWriteIndex + mReadResult - 1));
if (mReadResult != AudioRecord.ERROR_BAD_VALUE && mReadResult != AudioRecord.ERROR_INVALID_OPERATION) {
mBufferWriteIndex = mBufferWriteIndex + mReadResult - 1;
mTotalFramesWritten++;
if (mAudioEncoder != null) {
mEncodingService.submit(new EncoderTask(Encoder.this, EncoderTaskType.ENCODE_AUDIO_FRAME));
if (!mIsRecording && mAudioRecorder != null) {
mAudioRecorder.setRecordPositionUpdateListener(null);
mAudioRecorder.release();
mAudioRecorder = null;
Log.i(TAG, "stopped");
} else {
Log.e(TAG, "Read error");
