Samsung Galaxy S4 — Problems after upgrade to 5.0.1
Jan Linnenbank
  • Forum posts: 3
Apr 17, 2015, 4:53:59 PM via Website
After installing Android 5.0.1 (Lollipop) When I push an icon to move it to onother screen or to the dust bin I get the message 'Touchwiz-start stopped' and I can't move the icon. What can I do to make it work again? Thanks for help.
Lalit
  • Forum posts: 2,324
Apr 18, 2015, 9:10:32 AM via Website
Try following the step:
Head over to the Settings>Application Manager>Swipe Left to all>Look out for "Touchwiz" tap over it to clear the cache and the data stored.
Once done now try using it and see if that fixes the problem with the Touchwiz you are encountering !! :)
Jan Linnenbank
  • Forum posts: 3
Apr 20, 2015, 3:08:00 PM via Website
It's worse now. Ik got a weather widget on my home screen and I cannot remove it. What's your suggestion?
Thanks for your help.
Jan
Jan Linnenbank
  • Forum posts: 3
Apr 20, 2015, 8:35:03 PM via Website
I found a solution. Menu> Settings> My Device> Motions and Gestures and turned off all options. The problem with Touchwiz-start is solved. I can move icons now.
Jan
Mark Rgs
  • Forum posts: 5
Apr 22, 2015, 10:12:48 AM via Website
Anyone having trouble with ir blaster and watchon app after update?
