- Forum posts: 3
Mar 22, 2015, 10:23:24 AM via Website
Mar 22, 2015 10:23:24 AM via Website
How to shut the bright green battery charge graphic and noise off?
Mar 22, 2015, 1:08:22 PM via Website
Mar 22, 2015 1:08:22 PM via Website
Hi Robert. I've moved your question to the correct area, but you'll have to be more specific so we can help. The battery charging graphics tend to be built in to the ROM so if you can state your phone model and if you are on a stock or custom ROM it may help. I'm not sure what the noise is you mention either. Some ROMs have an audio alert when you connect/disconnect the charger, but I'm not familiar with a constant noise when charging
Sinkster
Mar 22, 2015, 4:19:44 PM via Website
Mar 22, 2015 4:19:44 PM via Website
This began with the last download from Android:When the charger is plugged in, a bright green animated graphic displays showing a battery figure with bubbles rising from below. Simultaneously, a muted beep noise starts and repeats every few seconds endlessly.
The phone has been on charge for twelve hours. Charge level is less than 80%.
I muted the phone, shut off everything I saw that looked possibly relevant all to no avail. This has to be industrial sabotage. Nobody could be this dumb.
My phone is a Samsung Galaxy S5. Model number SM-G900V
Android Version 4.4.4
Baseband Version G900VVRU1ANK7
Kernal version 3.4.0
dp@swdd6111#1
Fri Jan2 11:44:47 KST 2015
Build Number KTU84P G900V_4.4.4_0033
Se for Android status
Enforcing
SEPF_SM-G900V_4.4.4_0033
Fri Jan 02 11:44:28 2015
Hardware Version G900V 05
Security Software version
MDF v1.0 Release 3
VPN v1.4 Release 2
Whew, if there is anything else you need to know about this ridiculously dumb situation, let me know.
May 22, 2015, 8:17:37 AM via Website
May 22, 2015 8:17:37 AM via Website
Well, you're not the first one complain the bug.. the phone never reaches the 100% on battery charge after 4.4.4 upgrade.
Unplugging from wall and replugging seemed to have worked.
— modified on May 22, 2015, 8:18:47 AM
May 22, 2015, 11:03:22 AM via Website
May 22, 2015 11:03:22 AM via Website
What fool decided to send out such "upgrades" without testing them? Even by Microsoft standards this was lousy. I went with Android because it was less expensive and didn't have bloatware so I figured it had to be more efficient.
