Please help!
My htc droid Incredible does no longer auto rotate
Feb 20, 2015, 3:37:08 AM via Website
Feb 20, 2015 3:37:08 AM via Website
Please help!
Feb 20, 2015, 9:43:43 AM via Website
Feb 20, 2015 9:43:43 AM via Website
Make sure auto rotation is turned on from the notification bar. If it is already enabled, then you may want to reinstall the latest version of your stock firmware. Alternatively, you can try out different third apps that lets you auto rotate.
Feb 20, 2015, 11:57:09 AM via Website
Feb 20, 2015 11:57:09 AM via Website
Thanks,
But how do I reinstall the latest version of my stock firmware
Feb 20, 2015, 3:53:00 PM via Website
Feb 20, 2015 3:53:00 PM via Website
Did you try to reset your HTC?
Settings > Backup and Reset > Reset Phone > Ok > Ok.
Feb 20, 2015, 7:29:59 PM via Website
Feb 20, 2015 7:29:59 PM via Website
Hey @Koch fe, before moving forward in factory resetting your device like most of the member have already guided you over here, Make sure the auto screen rotation is checked, head over to the settings and look for the option display and gestures tap over it and the very first option you will see is Auto-rotate screen, make sure that its's ticked and again check if the screen auto rotates !!
Feb 20, 2015, 8:42:17 PM via Website
Feb 20, 2015 8:42:17 PM via Website
Hi
I have already ticked the auto rotate feature but it didn't work
Feb 21, 2015, 5:40:39 AM via Website
Feb 21, 2015 5:40:39 AM via Website
@Koch fe, if that's the case then you can move forward in performing factory resetting you can do that either by heading over to the
Tap Settings>Storage>Factory data reset>Reset phone>Erase everything.
or you can also factory reset your device by booting onto the boot loader menu
Note: Before moving forward with the factory reset make sure you have backup all of your data as it's going to wipe out all the data stored over your device.
Feb 21, 2015, 5:27:09 PM via Website
Feb 21, 2015 5:27:09 PM via Website
Thanks
I backed up all data with an app called back up pro but as I went on to reset factory data I was told that everything will be erased including all downloaded app, which means that I would lose the app along with the backup. What can I do then?
