- Forum posts: 78
Jan 19, 2015, 4:46:25 PM via Website
Jan 19, 2015 4:46:25 PM via Website
A cool new app Battery Saver
★★★ Introducing Battery Saver ★★★
[IMG]https://lh5.ggpht.com/427ybABw42rjPTPqhOAYhlfCALgwljARqRUoa0S8kxrjhfOdKy G83uKVdN9OsE_4Y42W=h900[/IMG] [IMG]https://lh3.ggpht.com/dAde8NOcuKkUfVCKF5xs-6roJ79LQsIzRdgoKM6easUs1-ZWa3F9JP3TC8tpZX3kqTU=h900[/IMG]
Description:
Ahorrar Bateria: Battery Saver
Ahorrar Bateria is an easy to use battery saving app. It is guaranteed to keep your smartphones and tablets running longer so that you get the best out of your mobile experience. New mobile devices always work smoothly and it isn’t until a few months later that you begin to notice slight declines in performance and productivity.
One of the biggest problems that come with an old smartphone or tablet is a shorter battery life. No matter how careful you are about charging your device properly or about using only the right chargers, a battery’s life and performance can only go so far. With Ahorrar Bateria, you can enjoy battery saver features that will have your mobile device’s battery functioning as if it were new. The best part is, this power saving app is free!
Install Ahorrar Bateria battery saving app and enjoy the following:
• Up to 75% additional battery life
• Choose from 3 battery saver modes to suite your situation. Select either ‘sleep’, ‘send messages’, or ‘study’ mode to maximize your battery life
• Lets you close unnecessary running apps so that you save more battery life
• Adjust screen brightness
• Set stand by time of screen to save battery
• Display battery status, device health, temperature, current, and voltage
• Allows you to block unwanted applications and widgets
• Comes with an easy to use interface
• Makes use of a convenient main application menu that lets you select settings effortlessly
• Provides tips on how to save battery life
• Available in both English and Spanish language
This power saving app will give you the assurance that your mobile device will be up and ready anytime you need it. No need to worry about having to turn your device on and off or about applying complicated settings just to save battery. You can even forego bringing your portable charging devices as this battery saving app will make sure that you are charged all day through.
The best battery saving app keeps your devices running when you need them the most. Accept calls, enjoy proper screen resolutions, use your apps and keep connected with everyone while using the app. Customize your settings so that you use the best power saving mode for any situation you are in. Whether you are in a meeting or class, on a commute, out with friends, or if you are asleep but need your device to be turned on, you won’t have to be concerned about it going off. You will never need to worry about how to save battery on your device as the app will do it for you so that you are able to use it when it matters.
Super convenient and easy to use, this app is the only thing you need to know on how to save battery life.
[video=youtube;FD3tZZfw8xM]https://www.youtube.com/watch?v=FD3tZZfw8xM[/video]
Link to google play: [url]https://play.google.com/store/apps/details?id=com.awesomesuperapps.batterysaver[/url]
Requires Android: 2.3 and up
I recommend you to download this new and awesome app.
Enjoy!!
