- Forum posts: 10
Dec 28, 2014, 11:50:54 PM via Website
Dec 28, 2014 11:50:54 PM via Website
I have Samsung Galaxy S3, any working tips to save more battery life, apps, options......?
Dec 29, 2014, 4:39:34 PM via Website
Dec 29, 2014 4:39:34 PM via Website
Well, @Sofiande in order to save battery what you can do is make sure that you keep the screen brightness to minimum or if available set it to auto, always choose dark wallpaper as it also helps in saving battery, there are also some battery saver apps that claims helping you saving battery by closing down the apps periodically !
You can also have a look over the post made by @Kris which I think can help you with the battery saving How to save battery life on your Android device: 16 tips to extend battery performance
There any many apps manage battery on Google play, you can search for them
Dec 30, 2014, 12:25:41 AM via Website
Dec 30, 2014 12:25:41 AM via Website
Thanks John F. @Kris post helped me a lot.
