- Forum posts: 21
Dec 17, 2014, 8:08:30 AM via Website
Dec 17, 2014 8:08:30 AM via Website
Hi everyone,
I'm trying to create a simple application.
My code is fine and everything worked perfectly a few days ago.
Now I cannot even run my application and gets a weird error.
I have only one activity and no jar files.
This is my Java code:
package binder.pictureslicense;
import android.app.Activity;
import android.app.AlertDialog;
import android.content.DialogInterface;
import android.os.Bundle;
import android.os.Handler;
import android.view.View;
import android.widget.EditText;
import android.widget.ImageView;
import android.widget.ProgressBar;
import android.widget.TextView;
import java.util.Random;
public class MainActivity extends Activity {
@Override
protected void onCreate(Bundle savedInstanceState) {
super.onCreate(savedInstanceState);
setContentView(R.layout.activity_main);
public void clearScreen(View view) {
clr();
private void clr() {
ImageView pic = (ImageView) findViewById(R.id.imageView);
EditText txt = (EditText) findViewById(R.id.IDNumber);
TextView txtQeus = (TextView) findViewById(R.id.txtQues);
pic.setImageResource(R.drawable.emptyface);
txt.setText("");
txtQeus.setVisibility(View.INVISIBLE);
private boolean checkID() {
int[] oneTwo = new int[]{1, 2, 1, 2, 1, 2, 1, 2};
int[] IDArr = new int[]{0, 0, 0, 0, 0, 0, 0, 0};
int sum = 0;
String str = txt.getText().toString();
int checkNum = Integer.parseInt(str.substring(str.length() - 1));
str = str.substring(0, str.length() - 1);
int num = Integer.parseInt(str);
str = String.valueOf(num);
int length = str.length();
for (int i = 0; i < length; i++)
IDArr[length - i - 1] = Integer.parseInt(str.substring(str.length() - 1 - i, str.length() - i));
for (int i = 0; i < 8; i++) {
int temp = oneTwo[i] * IDArr[i];
if (temp > 9)
temp = temp / 10 + temp % 10;
sum += temp;
int div = sum % 10;
div = 10 - div;
if (div == 10)
div = 0;
if (div == checkNum)
return true;
return false;
private boolean checkLength() {
if (str.length() > 9)
return false;
if (str.length() == 0)
return false;
return true;
private boolean checkNumbers() {
if (str.matches("[0-9]+"))
return true;
return false;
public void checkIDBtn(View view) {
if (checkLength()) {
if (checkNumbers()) {
if (checkID())
placePic();
else {
AlertDialog.Builder builder = new AlertDialog.Builder(this);
builder.setMessage("תעודת הזהות שהזנת אינה תקינה").setTitle("תעודת זהות לא תקינה");
builder.setPositiveButton("OK", new DialogInterface.OnClickListener() {
public void onClick(DialogInterface dialog, int id) {
dialog.cancel();
AlertDialog dialog = builder.create();
dialog.show();
clr();
} else {
builder.setMessage("אתה חייב להזין רק ספרות").setTitle("רק ספרות");
dialog.cancel();
dialog.show();
clr();
} else {
builder.setMessage("אתה חייב להזין מספר בעל 9 ספרות או פחות").setTitle("9 ספרות או פחות");
dialog.cancel();
dialog.show();
clr();
private void placePic() {
ProgressBar circle = (ProgressBar) findViewById(R.id.circle);
TextView txt = (TextView) findViewById(R.id.txtSearch);
circle.setVisibility(View.VISIBLE);
txt.setVisibility(View.VISIBLE);
final Handler handler = new Handler();
handler.postDelayed(new Runnable() {
public void run() {
Random rand = new Random();
int num = rand.nextInt(10) + 1;
txtQeus.setVisibility(View.VISIBLE);
circle.setVisibility(View.INVISIBLE);
txt.setVisibility(View.INVISIBLE);
switch (num) {
case 1:
pic.setImageResource(R.drawable.monkey1);
break;
case 2:
pic.setImageResource(R.drawable.monkey2);
break;
case 3:
pic.setImageResource(R.drawable.monkey3);
break;
case 4:
pic.setImageResource(R.drawable.monkey4);
break;
case 5:
pic.setImageResource(R.drawable.monkey5);
break;
case 6:
pic.setImageResource(R.drawable.monkey6);
break;
case 7:
pic.setImageResource(R.drawable.monkey7);
break;
case 8:
pic.setImageResource(R.drawable.monkey8);
break;
case 9:
pic.setImageResource(R.drawable.monkey9);
break;
case 10:
pic.setImageResource(R.drawable.monkey10);
break;
default:
break;
}, 5000);
This is my XML file:
<RelativeLayout xmlns:android="http://schemas.android.com/apk/res/android"
xmlns:tools="http://schemas.android.com/tools"
android:layout_width="match_parent"
android:layout_height="match_parent"
android:paddingLeft="@dimen/activity_horizontal_margin"
android:paddingRight="@dimen/activity_horizontal_margin"
android:paddingTop="@dimen/activity_vertical_margin"
android:paddingBottom="@dimen/activity_vertical_margin"
tools:context=".MainActivity"
android:background="@drawable/background">
<TextView
android:layout_width="wrap_content"
android:layout_height="wrap_content"
android:textAppearance="?android:attr/textAppearanceLarge"
android:text="הזן מספר תעודת זהות ותראה את התמונה המופיעה ברשיון שלך"
android:id="@+id/textView"
android:layout_alignParentTop="true"
android:gravity="center"
android:layout_centerHorizontal="true" />
<ImageView
android:layout_width="110dp"
android:layout_height="110dp"
android:id="@+id/imageView"
android:src="@drawable/emptyface"
android:layout_below="@+id/textView"
android:layout_marginTop="30dp" />
<TextView
android:textAppearance="?android:attr/textAppearanceMedium"
android:text="אנא הזן מספר תעודת זהות"
android:id="@+id/textView2"
android:layout_below="@+id/imageView"
<EditText
android:inputType="number"
android:ems="9"
android:id="@+id/IDNumber"
android:layout_below="@+id/textView2"
<Button
android:text="חפש"
android:id="@+id/btnSrc"
android:onClick="checkIDBtn"
android:layout_alignParentBottom="true"
android:layout_alignParentRight="true"
android:layout_alignParentEnd="true" />
<Button
android:text="אפס"
android:id="@+id/btnClr"
android:onClick="clearScreen"
android:layout_alignParentLeft="true"
android:layout_alignParentStart="true" />
<ProgressBar
style="?android:attr/progressBarStyleLarge"
android:id="@+id/circle"
android:visibility="invisible"
android:layout_centerVertical="true"
<TextView
android:text="מחפש..."
android:id="@+id/txtSearch"
android:layout_below="@+id/circle"
<TextView
android:text="באמת חשבת לראות את התמונה שלך ברשיון?
android:id="@+id/txtQues"
android:layout_below="@+id/IDNumber"
android:layout_marginTop="30dp"/>
</RelativeLayout>
I read somewhere that the problem might be on the build.gradle file. This is my build.gradle file:
apply plugin: 'com.android.application'
android {
compileSdkVersion 21
buildToolsVersion "21.1.2"
defaultConfig {
applicationId "binder.picturelicense"
minSdkVersion 15
targetSdkVersion 21
versionCode 1
versionName "1.0"
buildTypes {
release {
minifyEnabled false
proguardFiles getDefaultProguardFile('proguard-android.txt'), 'proguard-rules.pro'
dependencies {
compile fileTree(dir: 'libs', include: ['*.jar'])
compile 'com.android.support:appcompat-v7:21.0.3'
And finally this is the error I see when I try to run the application:
Error:Execution failed for task ':app:dexDebug'.
> com.android.ide.common.internal.LoggedErrorException: Failed to run command:
C:\Program Files (x86)\adt-bundle-windows-x86_64-20130917\sdk\build-tools\21.1.2\dx.bat --dex --no-optimize --output C:\Users\איציק\AndroidStudioProjects\PictureLicense\app\build\intermediates\dex\debug --input-list=C:\Users\איציק\AndroidStudioProjects\PictureLicense\app\build\intermediates\tmp\dex\debug\inputList.txt
Error Code:
1
Output:
UNEXPECTED TOP-LEVEL EXCEPTION:
java.lang.RuntimeException: C:\Users\׳?׳™׳¦׳™׳§\AndroidStudioProjects\PictureLicense\app\build\intermediates\classes\debug: file not found
at com.android.dex.util.FileUtils.readFile(FileUtils.java:51)
at com.android.dx.cf.direct.ClassPathOpener.processOne(ClassPathOpener.java:169)
at com.android.dx.cf.direct.ClassPathOpener.process(ClassPathOpener.java:144)
at com.android.dx.command.dexer.Main.processOne(Main.java:632)
at com.android.dx.command.dexer.Main.processAllFiles(Main.java:510)
at com.android.dx.command.dexer.Main.runMonoDex(Main.java:280)
at com.android.dx.command.dexer.Main.run(Main.java:246)
at com.android.dx.command.dexer.Main.main(Main.java:215)
at com.android.dx.command.Main.main(Main.java:106)
java.io.FileNotFoundException: C:\Users\׳?׳™׳¦׳™׳§\AndroidStudioProjects\PictureLicense\app\build\intermediates\pre-dexed\debug\support-annotations-21.0.3-7fe8a76469fdb827e43bf20f3c12ce539792c1fb.jar (למערכת אין אפשרות לאתר את הנתיב שצוין)
at java.util.zip.ZipFile.open(Native Method)
at java.util.zip.ZipFile.<init>(ZipFile.java:215)
at java.util.zip.ZipFile.<init>(ZipFile.java:145)
at java.util.zip.ZipFile.<init>(ZipFile.java:159)
at com.android.dx.cf.direct.ClassPathOpener.processArchive(ClassPathOpener.java:244)
at com.android.dx.cf.direct.ClassPathOpener.processOne(ClassPathOpener.java:166)
java.io.FileNotFoundException: C:\Users\׳?׳™׳¦׳™׳§\AndroidStudioProjects\PictureLicense\app\build\intermediates\pre-dexed\debug\internal_impl-21.0.3-ce53b1f9c132dc5c40800ec01310f130b6feab68.jar (למערכת אין אפשרות לאתר את הנתיב שצוין)
java.io.FileNotFoundException: C:\Users\׳?׳™׳¦׳™׳§\AndroidStudioProjects\PictureLicense\app\build\intermediates\pre-dexed\debug\classes-c4b80566cca6170006eb51a8b9aeaf044ce0b759.jar (למערכת אין אפשרות לאתר את הנתיב שצוין)
java.io.FileNotFoundException: C:\Users\׳?׳™׳¦׳™׳§\AndroidStudioProjects\PictureLicense\app\build\intermediates\pre-dexed\debug\classes-0289a8c73d1101ca747c692245c99e262ab5b2b9.jar (למערכת אין אפשרות לאתר את הנתיב שצוין)
5 errors; aborting
What do I need to change?
Thank you for your help!
