- Forum posts: 6
Nov 14, 2014, 4:12:32 AM via Website
Nov 14, 2014 4:12:32 AM via Website
Battery Saver Manager Application function to help save your phone's battery. This application provides features best to save battery time of your phone or tablet. Whenever the battery is low or goes too quickly reduced, then just press and turn on Battery Saver Manager application to enable the power-saving mode. than that in the Battery Saver Manager application is also equipped with Status & Widgets Switcher which allows you to launch applications with a single tap . So easy and quick to use .
Battery Saver Manager is equipped with a menu that aims to regulate the battery saving on your phone easily , such as:
Details Charge Mode ( which function regulate the charging of the battery )
Details Battery Condition
Task Killer ( show all running applications with details of the capacity is used)
Optimize data card ( Recommend saving battery & memory consumption )
Features battery saving mode :
Switching On / Off Airplane Mode
Managing peripheral brightness
Managing the device screen timeout ( Special provide notifications when your device's battery down )
Turn On / Off Wifi
Switching On / Off Cellular Data
Turn On / Off Bluetooth
Turn On / Off GPS
This application also provides three types of mode to save your battery when it runs low .
1. Saving Mode : (Recommended for use in low battery status )
2. Sleep mode : (Recommended for use when you are sleeping )
3. Customized mode (which you can adjust the battery saving setting freely depending on your needs and usage )
Download Link :
play.google.com/store/apps/details?id=com.digitalzone.batterysaver
