Problem with the Samsung S6312 Samsung Galaxy Young DUOS
yusif abdo
Nov 10, 2014, 7:47:52 AM via Website
Problem briefly when you update for Rom. Rom data appears on the home screen does not disappear
As in the attached photos
Photo0099 1415602041720
yusif abdo
Dec 31, 2014, 6:16:32 PM via Website
where any answer
DIY Suusie
  • Forum posts: 14
Jun 24, 2017, 1:42:35 PM via App
Hi, Yousif!
It's the Samsung Galaxy Y?
Samsung Galaxy S4 e Ace
  • Forum posts: 66
Sep 7, 2017, 4:56:06 PM via App
DIY Suusie
Hi, Yousif!
Samsung galaxy y is android 2.3.5
star mobile
Sep 23, 2017, 2:32:11 PM via Website
Just use z3x box software and use option disable factory mode in it ...
your problem will be solved 100%. and never forget to say thanks..
you can download software from here www.gsm4g.com/category/z3x-box-section
— modified on Sep 27, 2017, 11:22:42 AM
