Hi Guys,
I was wondering if you could help me out with the below issue basically I have 2 classes which the 2nd one doesn't show the toast captions yet the first one does am I doing something wrong here below is my code. any help would be greatly appreciated
1st class
package freelanceitceltd.ftpwithoutme_beta;
import android.app.Activity;
import android.os.Bundle;
import android.view.Menu;
import android.view.MenuItem;
import android.view.View;
import android.widget.Button;
import android.widget.Toast;
public class FTPWELCOME extends Activity {
@Override
protected void onCreate(Bundle savedInstanceState) {
super.onCreate(savedInstanceState);
manualentry();
private void manualentry() {
//create a reference to the button
Button manualscene = (Button) findViewById(R.id.connectftp);
//set the click listener to run the code.
manualscene.setOnClickListener(new View.OnClickListener() {
@Override
public void onClick(View v) {
Toast.makeText(
FTPWELCOME.this,
"Please fill out all of the below fields in order to connect or save your server parameters", Toast.LENGTH_LONG)
.show();
//navigates to the next step
setContentView(R.layout.activity_manualconfig);
@Override
public boolean onCreateOptionsMenu(Menu menu) {
// Inflate the menu; this adds items to the action bar if it is present.
getMenuInflater().inflate(R.menu.ftpwelcome, menu);
return true;
@Override
public boolean onOptionsItemSelected(MenuItem item) {
// Handle action bar item clicks here. The action bar will
// automatically handle clicks on the Home/Up button, so long
// as you specify a parent activity in AndroidManifest.xml.
int id = item.getItemId();
if (id == R.id.action_settings) {
return true;
return super.onOptionsItemSelected(item);
2nd class
public class manualconfig extends Activity {
@Override
savesetup();
connect();
public void savesetup() {
Button savedata = (Button) findViewById(R.id.saveconfig);
savedata.setOnClickListener(new View.OnClickListener() {
@Override
Toast.makeText(
manualconfig.this,
"Your connection setup details have been saved", Toast.LENGTH_LONG)
.show();
public void connect() {
Button comms = (Button) findViewById(R.id.connectme);
comms.setOnClickListener(new View.OnClickListener() {
@Override
Toast.makeText(
manualconfig.this,
"Your connection details have been saved also", Toast.LENGTH_LONG)
.show();
@Override
getMenuInflater().inflate(R.menu.manualconfig, menu);
return true;
@Override
return true;
