Samsung Galaxy S4 — Problems with Hotmail sync on Galaxy S4
Douglas Cunningham
May 1, 2014, 11:02:51 PM via Website
Since the Kit Kat 4.4.2 update I cannot receive my Hotmail e-mails . Any fixes available out there?
— modified on May 8, 2014, 10:24:38 AM by moderator
Tiff W
  • Forum posts: 9
May 2, 2014, 1:45:11 AM via Website
have you tried factory reset. it gives the new updated OS a clean plate to start and everything should work okay. but not sure if you want to do it.
thats only from my experience.
Loie Favre
  • Forum posts: 877
May 7, 2014, 6:53:50 PM via Website
Hey Douglas,
Tiff's solution might work for you, just remember that you need to make sure you back up your data before doing this. Doing a factory reset puts your phone back to square one, so even saved settings will be wiped.
Before doing that though, you could try doing a master Sync update:
Go to Settings, Data usage, menu and make sure Auto-sync data is checked.
Did this work for you?
