No file was created in src and layout folder in my project
Monabber Hossain
Mar 11, 2014, 7:24:30 PM via Website
I had created an android application project. But there was nothing in src and layout folder. Now what can I do? Please help me.
Here is my package explorer that can help you to understand my problem.
Clipboard01 1394637007178
— modified on Mar 12, 2014, 4:10:20 PM
Pascal P.
  • Forum posts: 11,294
Mar 13, 2014, 7:51:56 PM via Website
You can add a package and a Java File manually. Also the layout XML you can create in the layout folder
LG Pascal //It's not a bug, it's a feature. :) ;)
Monabber Hossain
Monabber Hossain
Mar 14, 2014, 6:57:49 PM via Website
Thank you for your answer.But why it was happened?
Pascal P.
Mar 15, 2014, 8:34:16 PM via Website
I don't know it can be the result of a failed instalation for example the sdk or eclipse or adt.
