Hello All ,
i have a Bluetouth Headset with mic inside , once paired the audio output is good using the BT headset , but the mic is not overrided !! , the phone still uses the built in mic !!
Any help how i can specify wich Mic i want to use ?
in my case:
headset Ref :MIC-BT03WT
Mic Spec:
Dimensions Micro Φ (4.5±0.1) x (5.0±0.1) mm
Sensibility Micro -54dB ±2dB
impedance Micro 100Hz—100 KHz
in my case:
Mic Spec:
