Mateus Pastore
- Forum posts: 1
Feb 22, 2014, 4:14:42 PM via Website
Feb 22, 2014 4:14:42 PM via Website
To having trouble installing this game , downloaded it by blackmart and when he starts the authentication fails.
So far so good , I used the lucky patcher to remove the check , I downloaded the file date and when will I start the game it appears the following error : 0x0e010040
and asks to contact support .
found in another topic (THE KING OF FIGHTERS ) was giving the same error .
for then follow the same steps that staff used to make it work and even then my game ESPGALUDA II did not work
I will leave the turorial of THE KING OF FIGHTERS below:
Please if anyone knows how to solve this problem for me a tip!
1. install apk
2 . Install lucky patcher
3 . Once installed the OPEN lucky patcher and put in FIRST OPTION
in automatic . (Note that it will be 1-7 with the 4 green had been
red)
4 . After doing that NOT OPEN THE GAME YET ! ( Uninstall Lucky
patcher , clean the leftovers , with APP2SD cache and restart the cel )
5 . (with wifi on ) Open the game and it will start to download the file date .
6 . Once downloaded will appear and place the SHORTCUT = NO option . and then games Start
7 . Ae only alegriiaaaa . ta run after exit the game and turn off the WIFI again and enter , it will work the normal
1. install apk
red)
