- Forum posts: 1
Mar 23, 2013, 8:52:01 PM via Website
Mar 23, 2013 8:52:01 PM via Website
More details:
- Occasionally I'll get a notification on the scroll down menu that says "USB storage damaged. It may need reformatting."
- When I connect it to my computer with the USB, the drive doesn't show up on "My Computer" (it usually does). IT DOES HOWEVER show up on my "Devices and Printers" on the "Control Panel" as a connected device.
I already did some researching on Google and found no solution that works. Anyone had this problem before and fixed it? Anyone have any idea how to fix it? I'll reformat or Factory reset if I need to, but I want to see if there are any alternative solutions since I don't want to lose my files. Thanks in advance.
