- Forum posts: 3
Feb 27, 2012, 7:08:05 AM via Website
Feb 27, 2012 7:08:05 AM via Website
With my HTC Cha cha, (android version 2.3.3) with either Office suite Pro or Kingsoft Office, the "FN" key to get the numbers or symbols located above the lower case and "SHIFT" key to get upper case does not always work in files. txt or. doc.
When it works (as opposed to typing text for a SMS, when you have to press FN and after the key for a number for example) I must hold FN and press simultaneously on the character to get a number. In addition to locking the FN / SHIFT by double pressing FN / SHIFT never works in a. Txt or. Doc, only for SMS.
Occasionally, I can get numbers / symbols or upper case with FN / SHIFT to a file. Txt or. Doc, then two lines later in the same file, it is impossible for me to get back . And on some files, it is impossible for me on the whole file.
As tihs problem occurs with several office suite that I could try, I put the HTC cha cha involved ....
Pb already met by one of you?
