Headphone issues
Dylan Ferguson
  • Forum posts: 14
Sep 14, 2011, 12:31:15 PM via Website
Picked up my Bionic yesterday and I love it. Put in my headphones this morning and noticed a buzzing noise, especially when pausing a song or the volume is down.Has anyone noticed this problem as well? It could be a deal-breaker for me.
jakson Robert
  • Forum posts: 64
Mar 2, 2012, 10:46:52 AM via Website
1. Try another headset to make sure that your current headset is not the problem
2. If you look inside the headset jack you will see a gold contact at the bottom. Most likely it is not making contact with the end of your headphones, thereby causing your headset not to play.
3. Grab a paperclip and unfold it - make a very small "L" on the bottom
4. GENTLY insert it into the jack and attempt to get under the contact on the bottom of the input. Gently pull upwards a few times.
5. Re-insert headset and see if it works.
Aaron Tilton
  • Forum posts: 834
Mar 2, 2012, 11:15:00 AM via Website
Nice tips!
Android News I Android Apps I > App Center
