Code problem
  • Answered
Zoran Kalman
  • Forum posts: 5
Jan 11, 2019, 9:21:24 PM via Website
There are no errors in the android studio, the application crashes. What I do wrong. . It happened when I inserted a part of the color change code. Here's the code:
public void buttonClickedIzracunaj(View v) {
    EditText visina = (EditText) findViewById(R.id.txtVisina);
    EditText tezina = (EditText) findViewById(R.id.txtTezina);
    TextView rezultat = (TextView) findViewById(R.id.txtRez);
    if (visina.getText().length() == 0 && tezina.getText().length() == 0) return;
    double vi = Double.parseDouble(visina.getText().toString());
    double te = Double.parseDouble(tezina.getText().toString());
    double ITM = te / ((vi / 100) * (vi / 100));
    rezultat.setText(String.format("%.2f", ITM));
    String value = rezultat.getText().toString();
    int i = Integer.parseInt(value);
    if(i<20){
        rezultat.setTextColor(Color.parseColor("blue"));
    }else if(i<=20 && i<25){
        rezultat.setTextColor(Color.parseColor("green"));
    }else if(i>25){
        rezultat.setTextColor(Color.parseColor("red"));
Best answer
Jesper Åman
  • Forum posts: 5
Jan 20, 2019, 8:40:42 AM via Website
Well, it's because the text of your TextView/s can not be parsed as a double; this is due to the comma, add this and it should be fine visina.getText().toString().replaceAll(",", ".")
Helpful?
CarlineBurchZoran Kalman
James Watson
  • Forum posts: 1,605
Jan 12, 2019, 5:33:40 AM via Website
Perhaps there will be an exception in Double.parseDouble() if the value of txtVisina is something like 'abcd'. The exception will result in an app crash.
You had better take advantage of try-catch method in your codes.
— modified on Jan 12, 2019, 6:22:59 AM
Helpful?
Alexandr Kritsin
Jan 18, 2019, 3:20:39 PM via Website
What error do you have?
Helpful?
Zoran Kalman
Zoran Kalman
  • Forum posts: 5
Jan 18, 2019, 5:47:54 PM via Website
Greeting.
Android studio has no errors. The application works on the emulator (API 22). The Samsung J3 2016 is launched but when I press the button calculate the application crashes. The message that writes to J3 "has been a mistake".
Helpful?
Jesper Åman
  • Forum posts: 5
Jan 19, 2019, 10:49:06 AM via Website
Can you post the stack trace from logcat in Android Studio?
Helpful?
Zoran Kalman
  • Forum posts: 5
Jan 19, 2019, 1:44:56 PM via Website
I think this is it:
01-19 13:40:45.682 4700-4700/com.example.marin.bmi_indextjelesnemase E/AndroidRuntime: FATAL EXCEPTION: main
Process: com.example.marin.bmi_indextjelesnemase, PID: 4700
java.lang.NumberFormatException: Invalid double: "21,46"
at java.lang.StringToReal.invalidReal(StringToReal.java:63)
at java.lang.StringToReal.initialParse(StringToReal.java:164)
at java.lang.StringToReal.parseDouble(StringToReal.java:282)
at java.lang.Double.parseDouble(Double.java:301)
at com.example.marin.bmi_indextjelesnemase.MainActivity$1.onClick(MainActivity.java:46)
at android.view.View.performClick(View.java:5246)
at android.widget.TextView.performClick(TextView.java:10620)
at android.view.View$PerformClick.run(View.java:21256)
at android.os.Handler.handleCallback(Handler.java:739)
at android.os.Handler.dispatchMessage(Handler.java:95)
at android.os.Looper.loop(Looper.java:145)
at android.app.ActivityThread.main(ActivityThread.java:7007)
at java.lang.reflect.Method.invoke(Native Method)
at java.lang.reflect.Method.invoke(Method.java:372)
at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:1404)
at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:1199)
Helpful?
CarlineBurch
James Watson
Jan 19, 2019, 2:36:16 PM via Website
It is clear. Invalid double: "21,46". Did you key in that data?
Helpful?
Zoran Kalman
  • Forum posts: 5
Jan 19, 2019, 2:43:29 PM via Website
Not.
This is the calculated data.
The problem appeared when I wrote a piece of code that changed color in TextView.
Helpful?
Best answer
Jesper Åman
  • Forum posts: 5
Helpful?
CarlineBurch
  • Forum posts: 18
Apr 8, 2019, 1:24:43 PM via Website
Helpful?
XavierJailing
  • Forum posts: 5
Apr 30, 2019, 8:54:32 AM via Website
If you can't fix it. Contact Branex.com they can also help you solve it.
Helpful?
  • Forum posts: 8
May 9, 2019, 4:06:58 PM via Website
Thank you.
Helpful?
