4 Tips To Speed Up Your Mi Device
F.Alam
  • Forum posts: 6
Dec 31, 2018, 7:42:52 AM via Website
1546239074699
Dear Mi Fans,
To keep your Android running quickly, you'll want to remove old apps and files that you don't rarely anymore. Clearing the cached data can also free up a lot of space and improve your phone's performance. Finally, you can perform a factory reset and restore the device to its original performance, this erases your app data and will reset your settings. Be sure to take backup of your personal files just in case
Uninstalling Old Apps
Most of we have a lot of apps which are rarely use . But do you know a lot of apps in device it's also cause of device storage killer and device slower. So if you uninstall old or rarely used apps you device will get free up space and speed up deviec.Here's the step how to uninstall old apps on MIUI 10. Open Security app then go to Manages App>> Uninstall>>Tick right side and uninstall.
1546238234160
Clearing Out Old Files
Whenever we need downloading song, movie or files etc. But most often forget to to delete them when not need more. Bit this old file can full up storage and device can be slower. Now I will show how to delete very old or unnecessary files. Open Download app>>Download file>>Press and hold any one of file then tick which file want to delete then press delete>>Press ok.
1546238235842
Clearing Cached data
This method works for all Android smartphones because the cache is something that takes a lot of space and most often requires manual cleaning. You will not lose any data to clear the cache and it will save a large part of memory. Here's the step to clear cache on MIUI 10. Go to Settings> Storage> Cache data. Once you tap on the cache data it will open a pop-up, it will ask you to delete it. Confirm it and your cache will be released. Also, after it is done manually, you can delete the cache at the time you submit the storage to your phone at any time.
1546238238058
Factory Resetting
If you think above all tips failer then you have to do Factory Reset to free up space and speed up device . But remember before do a Factory Reset you must take back up cause all file and data will be lost. For Factory Rest go to setting then Additional Settings>> Back Up & reset>> Reset phone
1546238239970
That's all about today's 4 easiest today to free up space and speed up devices.
— modified on Dec 31, 2018, 7:52:25 AM
Sagar Rathod
  • Forum posts: 13
Dec 31, 2018, 9:06:11 AM via Website
  1. Disable or reduce system animation scale
    In Settings > About Phone, tap on MIUI ROM version until it shows that developer options are enabled. Then head to Settings > Additional Settings > Developer Options > then alter the system animation scale.
    p1p11
  2. Restrict background app and autostart
    Also in Developer Options is the option to limit or disable background apps to reserve enough memory to ensure smooth performance. In Security, we can also disable apps from autostarting to shorten boot up time and save on RAM.
    p2p21
  3. Performance mode and system optimization
    In recent MIUI 6 updates, a new Optimize system performance is added. In Settings > Additional Settings > Battery, change your option for system optimization. If you wish for a snappy and smooth experience, you'll have to turn on Performance mode here.
    p3p31
  4. Force stop or uninstall apps
    Smartphones nowadays are usually common with heating and battery draining problems caused by apps. Users can check the battery consumption of apps and after determining the app that consumes the most resources and slows down the phone, stop the app from running anymore. Some times, apps that were not used can bog down the phone and consume system resources, thus it's recommended to remove the apps.
p4 p41
  1. Factory reset or fastboot flash.
    Some times, it's necessary that users factory reset their phone, especially when your phone is still running ludicrously slow after following the above steps. By clearing out your phone of all data, apps, images, audio et cetera, your phone will become "brand new" again after a factory reset. Do remember to make a back up of everything. Fastboot flashing via MI PC Suite will also remove all files in your phone. These processes will help to remove apps and files that causes the system to slow down.
    p5p51
martin smith
  • Forum posts: 277
Dec 31, 2018, 9:09:09 AM via Website
It's good to know about this... to improve the mi device performance. Thanks for sharing the link...
IT Blog
F.Alam
Danien Silver
  • Forum posts: 31
Dec 31, 2018, 4:51:18 PM via Website
I am using Xiaomi A2 Lite version. Overall it works well
HuyenPhamF.Alam
chayusiro
  • Forum posts: 69
Feb 14, 2019, 9:27:05 AM via Website
Nice sharing. To speed up your mi device, we can also use phone data cleaner app to help us clear up cache files, junk files, unwanted files. I am always do that. It's easy and safe.
— modified on Feb 15, 2019, 4:05:08 AM
