Beginners Guide To Download Pingpong Root Tool To Root S6 And S6 Edge
bella robey
  • Forum posts: 32
Nov 19, 2018, 6:22:05 AM via Website
pingpong_root
Rooting is a privilege which can be gained by any Android device owner by using a brave rooting tool like Pingpong Root utility. This is an exclusive rooting utility specially made to root any Android handset to modify the handset. Learn more about the tool from here.
What Is Pingpong Root Tool?
As you all know rooting is a process which will gain all the Admin privileges to any Android handsets. With the help of this Pingpong Rooting tool, anyone can root Samsung manufactured S6 and S6 Edge Android device and gain admin privileges easily. This was developed by a team of four members namely wushi, memeda, Qoobee, idl3r and along with the Kingoroot team members. Without using any alternative tools like PC or any other equipment the handset can be rooted. The most extraordinary feature about this tool is this can root any versions of Android Samsung devices and if you are using the older version then you can experience the best and quick root from your handset.
How Does It Work?
You may wonder that is this is the best alternative root tool for Samsung Galaxy S6 device. Yes, there is no any other rooting tool that can root S6 model and the Odin also can be listed below to conduct the program. The best thing about this tool is this will support to root the handset without touching the KNOX security on the system. Consequently, there is no doubt that it became the best deal among the hundreds of utilities that speedily get an eyeful the KNOX counter.
Guidelines To Install
First of all, take a full backup from your handset and check the device compatibility with the built number. Now follow all these simple steps to root Samsung S6 Handsets.
  1. Step 1: Now navigate to the System settings and tick unknown sources
    to install
  2. Step 2: To begin with the rooting process you need to download the
    tool from the official host on your Samsung Galaxy S6 device
  3. Step 3: Now open the downloaded application and tab the NEXT button
  4. Step 4: Now click on the INSTALL button to start the process
  5. Step 5: Now the utility will install the SuperSU in your device and
    show an error message like "You don't have any permissions"
  6. Step 6: Go back to the system and grant permissions and wait until
    to root the handset
Developers Credit
Thanks to all four developers who have made many users dream to a reality. The kingoroot is the best tool like that this Pingpong Root tool also an another major produced by the team. I hope this simple guide will help you with the rooting process. Happy rooting.:D
Source: Android Bug - One stop Android Rooting tools and tutorials for any device
palgarism
