Audio failure
Manuel Da Grimaldi
  • Forum posts: 20
Dec 17, 2017, 9:23:15 PM via Website
I have an Oukitel K6000. Phone calls are fine, but audio voice messages result in a very very low volume for recipient and also in the file left in my device. It happens the same when using WhatsApp calls but no when using WhatsApp video calls. I have uninstalled and reinstalled WhatsApp but these audio problem remain.
tony williams
tony williams
  • Forum posts: 47
Dec 18, 2017, 1:54:34 PM via Website
Hi have you had software update as that's latest phone and a good one , try clearing cache ,disable then re able in settings
Manuel Da Grimaldi
  • Forum posts: 20
Dec 18, 2017, 4:30:10 PM via Website
Thanks, Tony. Do you mean Android 6 software update, or you mean any other software? Please, be more specific.
I use to clear cache weekly, but I do not understand what I should disable and then re-enable in settings. I do not see a way to do that for cache.
James Watson
  • Forum posts: 1,605
Dec 19, 2017, 2:36:13 AM via Website
There are 2 points as below for your reference.
  1. Make sure that your WhatsApp is the latest version, V2.17.426.
  2. Check the Settings for your phone volume. Is the volume for 'Media' low while the one for 'Calls' is normal?
James Watson
Dec 19, 2017, 5:15:01 AM via Website
Settings for Volume
Volume
Manuel Da Grimaldi
  • Forum posts: 20
Dec 19, 2017, 9:05:18 AM via Website
My WhatsApp version is 2.17.427 and all volumes are at maximum.
teknolojihaberleri
Dec 30, 2017, 12:28:04 AM via Website
Thank you so much..
