Android studio and JVM problem
MrBurnzie
  • Forum posts: 7
May 20, 2016, 9:34:00 PM via Website
Hello.
I have an android studio problem. I get this error (on the image) even after I go add JAVA_HOME with the location of my jdkxxx/jre to the system variables.
Is there a fix?Capture
Cheers!
Vladimir S.
  • Forum posts: 266
May 20, 2016, 9:51:40 PM via Website
Hi MrBurnzie,
You need to install a 64-bit version of JDK. You can download it from there.
jdk64
— modified on May 20, 2016, 9:52:25 PM
MrBurnzie
  • Forum posts: 7
May 20, 2016, 10:14:29 PM via Website
Thx, downloading it.
But why jdk 7?
Vladimir S.
Vladimir S.
  • Forum posts: 266
May 20, 2016, 10:22:00 PM via Website
Sorry, you can use jdk 8, you are right :)
MrBurnzie
  • Forum posts: 7
May 20, 2016, 10:25:09 PM via Website
Capture 1463775889468
Still nothing
Vladimir S.
  • Forum posts: 266
May 20, 2016, 10:40:22 PM via Website
As you already have downloaded JDK8 64bit, set JAVA_HOME variable to C:\Program Files\Java\jdk1.8.0_91, without "\jre".
MrBurnzie
  • Forum posts: 7
May 20, 2016, 11:11:49 PM via Website
nope, still the same :(
Vladimir S.
  • Forum posts: 266
May 20, 2016, 11:32:03 PM via Website
Open properties of studio's shortcut (right mouse button). There can be studio.exeor studio64.exe, you need to launch a version what is suitable for installed OS.
MrBurnzie
  • Forum posts: 7
May 20, 2016, 11:42:10 PM via Website
still the same
Vladimir S.
  • Forum posts: 266
May 20, 2016, 11:49:54 PM via Website
You did not say what windows (32 or 64) is installed on your computer and what version (64 or 32) of Android Studio setup programm did you use...
MrBurnzie
  • Forum posts: 7
May 20, 2016, 11:55:39 PM via Website
I use windows 10 64 bit and I downloaded Android Studio 64Bit.
Vladimir S.
  • Forum posts: 266
May 21, 2016, 12:03:19 AM via Website
Try to set JAVA_HOME variable to C:\Program Files\Java\jdk1.7.0_79 if you did not yet.
MrBurnzie
  • Forum posts: 7
May 21, 2016, 12:30:57 AM via Website
Tried it
