@Override
public void onCreate(Bundle savedInstanceState){
super.onCreate(savedInstanceState);
setContentView(R.layout.authenticate_layout);
sm=(SensorManager) getSystemService(SENSOR_SERVICE);
accelerometer=sm.getDefaultSensor(Sensor.TYPE_ACCELEROMETER);
Button sigBtn = (Button) findViewById(R.id.t_signatureBtn);
sigBtn.setOnTouchListener(this);
public boolean onTouch(View v, MotionEvent event) {
switch(event.getAction()){
case MotionEvent.ACTION_DOWN: //PRESSSED
accStart();
break;
case MotionEvent.ACTION_UP: //RELEASED
accStop();
break;
return true;
protected void accStart(){
sm.registerListener(this, accelerometer, SensorManager.SENSOR_DELAY_NORMAL);
protected void accStop(){
sm.unregisterListener(this);
@Override
public void onSensorChanged(SensorEvent event) {
TextView acceleration = (TextView) findViewById(R.id.t_acceleration);
acceleration.setText("X: "+ event.values[0] +
"\nY: " + event.values[1] +
"\nZ: " + event.values[2]);
I have an apps that required Accelerometer sensor with onTouchListener implemented to registerSensorListener and stop the accelerometer once released.
I used SENSOR_DELAY_NORMAL to capture data. Speed can be monitored in the Textbox I set in onSensorchanged.
The bug I encountered was sometime I get SENSOR_DELAY_FASTEST speed instead of DELAY_NORMAL. Anyone have any idea what is happening? The phone I using is LG NEXUS 5. For example, I triggered the accelerometer, the speed is going on 5 data per seconds, then at the 5th seconds, it's speed changed to DELAY_FASTEST for few seconds then return back to DELAY_NORMAL.
