- Forum posts: 14
Nov 27, 2014, 2:15:09 PM via Website
Nov 27, 2014 2:15:09 PM via Website
Volume Button is a free Android volume control panel app to manage volume with just one tap. This volume control panel can be accessed from anywhere, even when you are using a full screen app. You don’t have to minimize the current app in order to adjust the volume levels of your Android device.
The app lets you adjust the volume level for Ring, Media, Alarm, System, and In-call Voice. All these controls have their respective sliders for the easy controlling.
All these things can normally be done from the Volume buttons on Android phones. But sometimes the buttons might be hard to reach due to the cover you have put on your phone, or the buttons might simply stop working. Also, the buttons change the volume of only one thing at a time (depending on which app you are currently on), but this Volume control panel lets you modify all the different volumes together.
Volume Control
The other cool thing about the Android volume control panel app is that the panel auto-closes after 3 seconds of inactivity. Apart from this, you can choose from two styles: Light and Dark.
Using this Android Volume Control Panel App to Manage Volume:
You can get the Volume Button app from by either searching on Google Play Store or by clicking on the link given at the end of this review. The app is of only 651KB, which means it won’t take much time to get the app and install it.
After installing the app, you have to tap on the app’s icon. It will launch the volume control panel, as shown in the screenshot below. You can see that there are controls for:Ring, Media, Alarm, System, and In-call Voice.
You can control any of them by simply sliding the slider corresponding to them. To decrease the volume, you need to slide left, while for increasing the volume, you need to slide right. If there is no inactivity for 3 seconds, then the volume control panel will auto close.
The app also offers some Settings changes, which you can access by tapping on Settings icon. It lets you choose the theme of the app (Light/Dark), Enable/Disable Notifications, Show/Hide Status Bar Icon, and edit which volume bars to show in the panel.
Volume Control Settings
You may also like: Quote Widget for Android app
Final Verdict:
Volume Button is an awesome Android volume control panel app to manage volume with just one tap. I really loved the app as it’s extremely easy to access and use. Do give this app a try if you want a fast and easy option for adjusting volume.
Get Volume Button here.
