Loie Favre
- Forum posts: 877
Apr 29, 2014, 12:29:22 PM via Website
Apr 29, 2014 12:29:22 PM via Website
Hey peeps!
If you feel like your phablet is vibrating too strongly or weakly, you are able to adjust the intensity at which it does this.
All you need to do is go into the settings --> device --> sound and Vibration intensity.
You can adjust it differently for incoming calls, notifications and haptic feedback. For example, if you are playing a game with haptic feedback, you can set it to the max to get the most ''exciting'' experience and when your phone rings, you can ensure that it won't vibrate itself off the table completely!
Hope this helped!
Recommended editorial content
